Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
Thread: COS help?
  1. #21
    Jan 2012
    Would you be willing to set your tunetool fueling units to EQR or Lambda rather than AFR...?
    Would you be willing to use GM.EQIVRATIO and wideband Lambda for correcting the VE/MAF tables...?
    Do you have FlashScan V1 or V2...?
    Which wideband do you have...?
    It is a SD tune 2 bar the MAF has been removed and replaced with a IAT sensor.
    Yes I would be willing to just curious to the reasoning of why. I set it to AFR because thats what my wideband reads and is easiest for me to comprehend.
    I could learn to correct the ve table using lambda.
    I have a V2
    I have a AEM wideband http://www.aemelectronics.com/wideba...fuel-gauge-25/
    and also a innovate LM-1 (The innovate is not set up to log with EFIlive yet just the AEM is)
  2. #22
    Jan 2012
    Your IFR is set to 71.65 g/s... wrong units...
    go Edit->Configure Display Units, find B4001, set the Data units to Imperial (lb/hr), exit, restart tunetool, fix B4001.
    I can only change it to lb/min how can I change it to lb/hr?
  3. #23
    Jan 2012
    Set PE Enable B3616 to same as 2002 Camaro (65% below 3200 rpm, 35% above 3200 rpm).
    Fixed it
    Check B0701, B0504, B1301... if you don't have those systems then disable them.
    They appear to be disabled to me already.
    BTW: shift points are easier to figure out if you set D0960,1,2 to 100% everywhere.
    Changed
    BTW:
    WOT upshift and downshift MPH values are too close (and make sure to keep each upshift above its corresponding downshift).
    Set shift times to 0.3 seconds.
    Change all shift times (1-2, 2-3, 3-4) to say .3 in all areas? Where do i find the MPH values?
    Thanks for the education!!!
  4. #24
    Quote Originally Posted by yzriders182 View Post
    Then also do this first:
    go Edit-Properties and change the flowarate units to lb/hr... then goto Edit->Configure Display Properties and set B4001 to Imperial.
  5. #25
    Did you find the WOT MPH upshift/downshift parameters...?
  6. #26
    Jan 2012
    Ok got it changed over to lb/hr.
    I did find the shift tables but I am not understanding what I should do with those tables. Just to update this is my current tune file Cos3 5-11 Riebel.tun
    Again thanks for the help.
  7. #27
    For example, the WOT 2->1 downshift MPH should be at least 5 mph (or more) below the WOT 1->2 upshift MPH.
    Ditto for WOT 3->2/2->3 and WOT 4->3/3->4.
    Yours are too close (or maybe overlapping... I don't remember what I saw the other day).
  8. #28
    Jan 2012
    Got ya I'll work on that. Thanks
  9. #29
    Jan 2012
    For my 3-4 up shift 50% throttle and up is set to max. Does that seem right?
  10. #30
    Since vehicle can't reach that speed, then it inhibits the 3->4 upshift from 50% and up.
    Post a screenshot.
  1. Is there any COS for e38 other than the ethanol COS ?
    By wesam in forum E37, E38 & E67 PFI ECM's
    Last Post: July 8th, 2012, 09:54 PM
  2. switched from COS 3 to COS 5 now reduced power mode
    By CRU SS N in forum Custom Operating Systems
    Last Post: April 26th, 2010, 04:48 PM
  3. COS 3 or COS 5 for 2000 Corvette?
    By onfire in forum Custom Operating Systems
    Last Post: July 29th, 2009, 04:22 AM
  4. COS 3 or COS 5 for a 2000 corvette?
    By onfire in forum Gen III V8 Specific
    Last Post: July 7th, 2009, 06:59 AM
  5. Cos 2
    By southern in forum Custom Operating Systems
    Last Post: May 29th, 2007, 04:29 AM
