Results 1 to 5 of 5
Thread: Any Advice
    Feb 2013
    Default Any Advice
    I have an 08 6.7 cummins. Currently having files tuned by Anarchy Diesel (He's been great) I want to learn to write my own tunes, but dont have a bunch of money to spend on classes or reference materials. Any ideas, suggestions? How does on find out about all the different parameters and what each affects as well as safe limits?
    Read, read, read. Then read 5x as much again.
    Realize this isnt a walk in the park, a LOT of time, development, and money goes into developing tunes so if you want to learn how to do it yourself be prepared to spend a lot of time and effort. I started back in 2006 and Im still learning every day if that says something. Not trying to scare you away, just making sure you know what you're getting into and the time commitment it requires. Good luck, ask LOTS of question on here!
    2013 Sonic RS Manual - 1.4L I4T E78, starting the mods
    Feb 2013
    I have the time, and other diesel enthusiast have been great help. Just looking for as much info as I can get. This forum has been a great start and Efi live has wonderful quick starts for scanning, logging, and flashing.
    Jul 2012
    As stated it all a learning process. With all the updates in changes that go with EFi Live. Ill say this do small changes, in try them. As you learn more change more. Always back up your stock file's on disk and your hard drive. Learn to use the timing calculator it will be your friend.
    Mar 2009
    Once you do start changing tables smooth them out. When you pull a stock file look at how rough and rigid they are. Smooth them out and slowly add little by little 5% at a time. Flash, log, examine, adjust, flash, log, examine, adjust and so on. There is a lot of time involved and plenty of guys on here willing to lend a hand. I have been at it about a year now and have some good friends willing to let me make small adjustments and learn off of there trucks. I also got lucky and got into one of Zach's of Starlite Diesel's classes and learned a ton.
    2002 Chevy Duramax with a few supporting mods.
  1. Advice Please
    By Global-i in forum Custom Operating Systems
    Last Post: May 23rd, 2010, 06:27 PM
  2. Advice?
    By MScott09 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 6th, 2009, 12:29 PM
  3. Need some advice ...
    By Garry in forum Gen III V8 Specific
    Last Post: December 8th, 2007, 10:49 PM
  4. Little advice please...
    Last Post: November 18th, 2007, 01:04 PM
  5. Need some advice please.
    By pushed2dmax in forum Gen III V8 Specific
    Last Post: August 23rd, 2007, 04:46 AM
