What AFRs pre-cats are people aiming for when tuning Turbos LS1s?
What is a recommended curve for rpm and map ??
Oztrack
EFILive Tuning Consultant
Worldwide Remote Tuning Service
2006 NSW Super Street Drag Racing Champion
www.oztrack.com.au
I shoot for around 11.5-11.8 with about 17-18* of timing on my 4.8. I'm geting a meth kit next week, so I will see if I can run a little more timing and some more boost as well.
I run my wideband in the rear of my truck, right after the turbo. Worked fine when I had the cats on there, and read the same, when I took them off other then the ajusting I had to do for the increase in flow. But the cats didn't apear to make any diffreace in the reading of the WB.
The std sensors live just after the turbo on factory cars and they last just fine.her than
I personally run turbo cars between 12.5 and 12:1 I find that running richer than that loses power. Running like that with a little less advance is the same or better power wise than richer with more timing.
The richer mixtures also leaves lots of unburnt fuel pumping out of the exhaust
\"You Can Never Have Enough Horsepower\"
Would this be the same for us SC guys? I realize the tuning would be slightly diff from a Turbo set up but are most FI set ups looking for that same general number...?
http://gmhightechperformance.com/features/htp_0311_asp/
New project under construction...408 LS2 w/ ATI F1 SC / Custom build by IconAutosports / Tx Lic. LV2SPD / Blk.'02 HD 2500 Silverado / Indigo '02 RoadStar "Warrior"
I use the same afr for turbo and sc. in vacuum same as na.
