Results 1 to 6 of 6
Thread: AFRs and Turbos
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Default AFRs and Turbos
    What AFRs pre-cats are people aiming for when tuning Turbos LS1s?
    What is a recommended curve for rpm and map ??
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    Jun 2005
    11.5 AFR under boost is what most guys aim for. I don't know many turbo guys who still run cats, and definitely don't know anyone running the wbo2 in front of the cats -- the pressure up there would kill the sensor in a hurry I'd think.
    Hello, my name is Erik and I am a horsepower addict...
    Sep 2005
    I shoot for around 11.5-11.8 with about 17-18* of timing on my 4.8. I'm geting a meth kit next week, so I will see if I can run a little more timing and some more boost as well.
    I run my wideband in the rear of my truck, right after the turbo. Worked fine when I had the cats on there, and read the same, when I took them off other then the ajusting I had to do for the increase in flow. But the cats didn't apear to make any diffreace in the reading of the WB.
    Jul 2005
    The std sensors live just after the turbo on factory cars and they last just fine.her than
    I personally run turbo cars between 12.5 and 12:1 I find that running richer than that loses power. Running like that with a little less advance is the same or better power wise than richer with more timing.
    The richer mixtures also leaves lots of unburnt fuel pumping out of the exhaust
    \"You Can Never Have Enough Horsepower\"
    Apr 2006
    Would this be the same for us SC guys? I realize the tuning would be slightly diff from a Turbo set up but are most FI set ups looking for that same general number...?
    http://gmhightechperformance.com/features/htp_0311_asp/
    New project under construction...408 LS2 w/ ATI F1 SC / Custom build by IconAutosports / Tx Lic. LV2SPD / Blk.'02 HD 2500 Silverado / Indigo '02 RoadStar "Warrior"
    Jul 2005
    I use the same afr for turbo and sc. in vacuum same as na.
  1. Custom OS w/Twin Turbos B5956
    By lplott in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 8th, 2006, 02:50 AM
  2. Scenning just AFRs
    By oztracktuning in forum General
    Last Post: May 15th, 2006, 12:12 AM
  3. AutoVE w/turbos, etc
    Last Post: March 15th, 2006, 04:27 PM
  4. LM-1 AFRs in Scan off the scale.
    By curtbriggs in forum General
    Last Post: December 24th, 2005, 06:25 AM
