Results 1 to 10 of 10
Thread: lb7 boot loader rejected
    Junior Member hotrod87's Avatar
    Feb 2013
    Default lb7 boot loader rejected
    im trying to read the stock tune in a 03 lb7 will not unlock ecm keeps sayin boot loader rejected. vin is something like 2?????????#?? had a banks disabled speed loader and hooked up bale connecters as factory??? also tried alt keys and low speed..
    Probably corrupted by TIS during a dealer update, not much that can be done unfortunately if you have already tried the ALT Keys option.
    Feb 2013
    I worried about that.. so basically need different ecm then? if so what needs to be done with a different used ecm to make it work with the truck :( thanks for the help..
    Feb 2013
    not sure if these will help
ID:	14644   Click image for larger version.
    Mar 2009
    Disconnect the batteries for 30 minutes, then reconnect them and try to pull the tune with the V8 software. I know I have ran into the bootloader error with my own LB7 on more than one occasion with the V7.5 software, but the V8 normally goes through.
    Feb 2013
    I do see that I have dsp5 tune and that OS matches the gm OS for this truck.. but im guessing it wont let me flash either let alone flash over
    Mar 2009
    You NEED the stock tune to start with, TRUST ME on this one. Your other tune may work, then again it could disable your power windows, locks, shut your A/C off, no cruise, and a host of other issues could occur by putting the wrong tune file into a 03-05 truck.
    Feb 2013
    Ok thanks i wont try it lol.. but i will try the v8 but does that look like it could be corrupt in the pics thanks
    Feb 2013
    well I got a used ecm out of a 03 and put it in and read the stock tune in that ecm just fine.. OS ended up being the exact same except the speedo calibration number.. so I changed the vin and it starts and no security problems thanks guys but what could be different in the speedometer system? old speed id # was 15076393 new was 15076392
    Jan 2010
    I had my truck reflashed because i didnt have the stock tune and the GM tech was having issues reflashing it because i had an aftermarket radio so he had to install his stock radio so he could finish reflashing my truck and my truck is saying the same thing now as yours was hotrod87. So the only fix to this issue is buying a new ECM???
    2001 LB7
  1. Boot loader rejected, custom key?
    By Wheelz in forum Duramax LB7
    Last Post: February 12th, 2013, 04:10 AM
  2. Boot loader rejected
    By nonnieselman in forum Gen III V8 Specific
    Last Post: September 27th, 2012, 01:09 PM
  3. boot loader problem
    By skyhighsami in forum Diesel
    Last Post: July 7th, 2010, 06:50 PM
  4. Bootloader rejected
    By lilly in forum Duramax LLY
    Last Post: June 28th, 2009, 02:48 AM
  5. Boot Loader Error
    By dlandsvZ28 in forum FlashScan V1
    Last Post: June 24th, 2007, 02:32 AM
