Page 11 of 11 FirstFirst ... 91011
Results 101 to 105 of 105
Thread: Low Performance 6.7
  1. #101
    Member mpdtune's Avatar
    Jul 2013
    Looks like it's fueling good now. Those smarty files run crazy duration. At least there's a decent base file to start with now. Upgrade to a CSP5 file will give you a lot more control. 3100us is about the limit of duration on a stock CP3.
  2. #102
    Dec 2011
    I agree on the e2536 table good to see you got it working!
  3. #103
    Member WetMtnCrd's Avatar
    Jan 2013
    Thanks for all the help on this. Been quite a challenge getting these C&C ecm's in the conversion trucks to work well. This is what forums are supposed to be---sharing and learning. Too many people think their knowledge and info are on the level of national security and require large monetary investment to share. Thanks again.
    Haven't looked into the CSP5 stuff yet. Will have to do that. Need to investigate a couple parameters to see if they are affecting my low throttle/rpm operation. Mainly the IAT, AAT, and ECT. Don't know why EFI doesn't read the ECT. Zeus read it ok so I know it's connected but the others were never looked at. But there are a couple different options ( SAE and CM_*) for pid's in the EFI pid tables. Just have to figure out what "group" they are in and see what works. That's my next priority--to get the mileage up.
    2000 F350. Cummins 6.7 c&c. Allison 5sp. 4" ProComp lift. ARP head studs, BD Power Super B Special turbo, grid delete w/Shibby inline, ATS exhaust manifold, 5" exhaust w/AeroTurbine.
  4. #104
    Jul 2013
    Flashing to CSP5 will enable EDA logging. Makes life much easier.
  5. #105
    Oct 2020
    I'm glad I found this post. I'm running into this exact problem myself on an 08 pickup ECM. What exactly was changed to remove the limits?
  1. Transmission "hunting" at low speed/low throttle
    By skneeland in forum Cummins 5.9L
    Last Post: October 4th, 2011, 08:13 AM
  2. Normal Vs Performance
    By bstuder11 in forum Gen III V8 Specific
    Last Post: April 20th, 2011, 01:03 PM
  3. Is 45* too high for low load low rpm cruising?
    By the Dragon in forum General
    Last Post: February 13th, 2011, 12:43 PM
  4. Look what Hennessey Performance uses!
    By onegonewild in forum Lounge
    Last Post: December 4th, 2010, 05:20 PM
  5. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 11:56 AM
