Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 105
Thread: Low Performance 6.7
  1. #21
    What Duane said.
    Post the tune that you're currently using and Id be happy to look through it for you.
  2. #22
    Member WetMtnCrd's Avatar
    Jan 2013
    Quote Originally Posted by KhakiCummins View Post
    Have you adjusted the limiter tables?
    Which ones? Basically I have anything that can be disabled -- disabled. So all that stuff should be disabled. I had to do that just to get it to run without a VGT and all the other sensors and modules that a OEM Dodge truck has that my Fumins doesn't have. And that's been somewhat of challenge in itself.
    2000 F350. Cummins 6.7 c&c. Allison 5sp. 4" ProComp lift. ARP head studs, BD Power Super B Special turbo, grid delete w/Shibby inline, ATS exhaust manifold, 5" exhaust w/AeroTurbine.
  3. #23
    Jan 2013
    What Duane said.
    CMC_0002 DTC Disable.ctz
    I think I got it attached. Here's the file I'm using. Good luck. It doesn't fuel above 94 mm3 either.
  4. #24
    Ill look at it in the morning with fresh eyes, do you happen to have a log of it not fueling past 94mm3?
    And you just do not have a VSS feed into the ECM correct? All other sensors except VGT and VATS/security are there?
    What are your goals with this, how many RPMs do you want/can you run? Mods on the motor?
  5. #25
    Senior Member KhakiCummins's Avatar
    Sep 2011
    Quote Originally Posted by WetMtnCrd View Post
    The tables that I'm talking about are under the "Injection Quantity" folder. You will see about 7 or 8 sub folders in there. One of them will be "Limiters".
    I'll take a look at the tune this evening as well. Eric has a lot more experience with this than I do though so I'm sure he'll figure it out...
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
  6. #26
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    CMC_0002 DTC Disable_1.ctzdisabled the other limiters for you. A data log of your truck driving would definately help get it running right.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
  7. #27
    Nov 2010
    Default Low Performance 6.7
    I've adjusted everything I could think of...and still it hits a mm3 limiter.
    Increased duration below 90mm3 and got it to run ok...but still SLAMS a mm3 limiter ~90mm3
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  8. #28
    Jun 2011
    Les, I would say that it is the load based limiter that is killing it. We have a fummins w/6.7 that should be running in the next couple of days and I imagine I will be fighting the same thing. When Zach and I were tag teaming Richard Madsen's truck it reacted the same way.
    423-506-7427
  9. #29
    Nov 2010
    Quote Originally Posted by anarchydiesel View Post
    What was the fix? Or wasn't there one?
    Les Szmidt
    2007 5.9 Dodge Ram
  10. #30
    Sounds like the 6.7L load based stuff, is it related to the lack of a VSS signal?
    Ive never done a swap like this, the guys that have probably have a better idea of what's up.
  1. Transmission "hunting" at low speed/low throttle
    By skneeland in forum Cummins 5.9L
    Last Post: October 4th, 2011, 09:13 AM
  2. Normal Vs Performance
    By bstuder11 in forum Gen III V8 Specific
    Last Post: April 20th, 2011, 02:03 PM
  3. Is 45* too high for low load low rpm cruising?
    By the Dragon in forum General
    Last Post: February 13th, 2011, 01:43 PM
  4. Look what Hennessey Performance uses!
    By onegonewild in forum Lounge
    Last Post: December 4th, 2010, 06:20 PM
  5. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
