Results 1 to 10 of 17
Thread: 4L80e swap, won't shift 1>2 WOT
    Jun 2008
    Default 4L80e swap, won't shift 1>2 WOT
    Ok first off it's an 04 Silverado 1500, I'm using EFILIVE with custom OS 2, and of course I did the 4L80e segment swap. We've done many other 4L80e swaps and never had this problem before. The only thing I did different is not wire in the front input speed sensor, but I did turn all the DTC processing enablers off for it and disabled all the slip test stuff too. Shouldn't this work? It drives around just fine at all part throttle driving and the 2>3 WOT works fine too???? Also this trans was taken from my '89 turbo LS swapped truck and worked fine in there....
    -John
    1991 RCSB 2WD Sierra LQ4 swap, 220/224 112 cam, Twin VSR 6766 turbos
    4L80e w/shift kit, PY 3600, and 3.73 gears.
    22 PSI and E85, 4300# with driver. 9.7@138, 1.47 sixty
    :drivin:
    Make sure the 2->1 WOT MPH is lower than the 1->2 WOT MPH.
    Jun 2008
    Yup its set at 19mph on the wot and part throttle tables
    -John
    :drivin:
    Lower the 1->2 WOT MPH (and make sure to keep the 2->1 WOT MPH lower than it), and lower the 1->2 WOT RPM until you see the shift...
    Stupid little things first:
    Did you change the ratios?
    Did you adjust the shift points?
    Did you use the A4 trans spreadsheet to make sure the upshift/downshift tables don't cross? (Ive found this makes or breaks a trans tune.)
    If you can, post the tune so we can check it out. If not, feel free to email it to me: <my username> @gmail.com.
    Jun 2008
    Truck will go like 50mph in first, rpm point is set to 6000... Still wont shift
    Yes I did all those things as well...
    -John
    :drivin:
    Hi John,
    The WOT downshift MPH should be set lower than the corresponding WOT upshift MPH...
    yours are the opposite (higher), see this in your tune file (this keeps it downshifted, i.e. no WOT 1->2 shift):
Name:	4L80E WOT shiftpoints backwards.png
    Also, set the Throttle kickdown tables to 100% in all cells.
    And, after making the WOT downshift MPH's lower than the corresponding WOT upshift MPH's, lower the WOT RPM's to get the shifts...
    then once you see it doing those shifts, slowly increase the WOT RPM's and/or the WOT MPH's until it shifts at the desired RPM and/or MPH.
    Jun 2008
    Are those tables gonna make a difference at 40+ mph? I want it to shift at like 45-50mph at 6800 RPM.
    -John
    :drivin:
    Jun 2008
    Over on performancetrucks.net guys were saying it was because I didn't have my ISS sensor hooked up...
    -John
    :drivin:
  1. 4L80E no 2-3 shift at WOT
    By THEFERMANATOR in forum Gen III V8 Specific
    Last Post: November 9th, 2012, 12:19 PM
  2. 4L80E Will NOT SHIFT WOT
    By Mike@Vengeance in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 9th, 2012, 08:27 AM
  3. trans won't shift at WOT
    By lilicedout24 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 4th, 2010, 09:54 AM
  4. 4L80E swap
    By grec-O-face in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 3rd, 2008, 12:36 AM
  5. Truck won't shift at WOT
    Last Post: May 14th, 2006, 05:52 AM
