Quick question(s)...?
When working with AutoVE:
1. Do you have to import the exact (B3605) table that the AutoVE tutorial gives you into the tune you're working with? Or can/should you alter it for any given AFR you want to target in any given cell?
2. After you're done tuning with AutoVE and you're ready to turn on the o2 and MAF sensors, should you just leave the imported (B3605) tutorial (or your own) table in your final calibration, or do you switch it back the the stock table?
Common sense tells me to leave the (B3605) table in there once AutoVE is completed so the fueling stays accurate, but I've been proven wrong many times before...
-john
