Results 1 to 2 of 2
Thread: 2003 c6500 3126cat allison trans swap?
    Aug 2012
    Default 2003 c6500 3126cat allison trans swap?
    I have a 2003 GMC C6500 with cat 3126 diesel.
    The Allison 2400 transmission broke and customer swapped a 2200 from a 2004 f650 that had a 5.9 Cummings diesel in it.
    Now vehicle goes into limp mode when it shifts to second gear.
    My question is can efi live re-flash tcm with new tune for the 2200 Allison (has higher 1st gear).
    Can you connect to the TCM?
    Try using V8 and using the Autodetect feature to see if it can read the TCM.
    There's a good chance it wont work, but I honestly dont know. If you know the TCM is an AL5 or A40, it might however.
  1. Trans Segment Swap?
    By LS-SWAPPER in forum General (Petrol, Gas, Ethanol)
    Last Post: September 17th, 2012, 08:39 AM
  2. 2009 Silverado 4.3l/4l60 to a 6.2/4l80 engine/trans swap = ABS lite
    By mowton in forum Conversions / Aftermarket Parts
    Last Post: May 13th, 2012, 04:38 AM
  3. Replies: 0
    Last Post: January 4th, 2012, 04:42 PM
  4. trans tuning for the allison
    By Dmaxvaz in forum Diesel
    Last Post: February 16th, 2011, 06:57 AM
  5. Trans swap - GenIV pcm T42 question
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 24th, 2008, 06:36 PM
