Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: EFILive RC 1 (March 01, 2013)
  1. #31
    See my responses in red ink:
    Quote Originally Posted by Biodiesel66 View Post
    Have not seen this problem posted yet.
    When using EFILive scan & tune, F5, BBX.
    When setting up selected PIDs, PID properties, Custom PID properties. The quick select unit are not showing saved when selecting OK.
    > post a screenshot.
    While BBL the V2 displays metric, but playback the saved log file displays the correct units that were selected.
    > V2 and V7 scantool units display is regardless... in scantool, pids can be displayed in either units.
    When adding pre selected Calculated PID names to V7 Scan Tool Compatibility Settings. The PIDs don't show in the logged playback file. You have to manually select the PID to display in the playback. They are in the option.txt.
    > calc pids won't show on V2, but they should be preselected when you view the log file in the V7 scantool... did you specify the full pid name (e.g. "CALC.WO2BEN")...?
  2. #32
    Confirmed. Fixed in RC2.
    Thanks for finding and reporting these issues.
  3. #33
    Mar 2012
    I am getting random access denied issues. I provided a screen shot.
  4. #34
    Quote Originally Posted by SkinnyPedal View Post
    You have to run EFILive software with Administrator privileges...
    Win 7/8 is preventing EFILive software from writing that file in that folder because it was not run with sufficient privilege (i.e. need Administrator rights in order to write in that folder).
  5. #35
    Mar 2012
    Thanks! Never ran into that until installing RC 1.
  6. #36
  1. 2013 EFILive Training Classes
    By zfuller123 in forum General (Diesel)
    Last Post: September 23rd, 2013, 05:22 AM
  2. EFILive Class in Kinder LA March 3-4th 2012, Duramax and Cummins
    By dansdieselp in forum General (Diesel)
    Last Post: January 8th, 2012, 01:38 PM
  3. Replies: 0
    Last Post: January 7th, 2012, 04:01 PM
