I am using a AEM wideband in serial mode. I need help making a pid to tune my VE table. I have 9.8 afr in b3601 and when I log with ext_wbo2 Ben I get the wrong BEN. Do I need to make a custom calac. pid to dial in my VE? How do I make a custom pid?
Do you have V1 or V2...?
Which wideband do you have...?
WO2BEN uses serial comms Lambda from the wideband, does your wideband support this...?
Post your calc_pids.txt file here so I can see if it already contains calc pids.
I am using a V2. The AEM wideband is the one with te controller built into the gauge don't know the part no. I can view Lambda on the v2 but it won't log serial lambda it only logs serial ext_wbo2. My laptop is at the dyno so I cant post my calc_pids.txt right now
