Results 1 to 6 of 6
Thread: Not entering PE Mode
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Default Not entering PE Mode
    I noticed yesterday my car is not entering PE mode using 129003
    I have it to enable at 95% TP. But the desired AFR is following the table that specifies AFRS at MAP and RPM. I was hoping to be able to fine tune WOT AFRS using the PE table and its own IAT correction.
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    Jun 2005
    Is your MAP enable set low enough?
    Hello, my name is Erik and I am a horsepower addict...
    Jan 2005
    For some reason, I seem to recall the PCM will take the richest of the two values (commanded or PE) and apply it when entering PE. Don't hold my feet to the fire on that one though.
    Oct 2005
    My understanding too. Will take richest.
    However for NA apps word is that running a map only PE works good.
    You can fuel off B3647 solely. Forget TPS, no point.
    2014 VF SV LS3 Maloo.
    Nov 2005
    I was hoping to use the PE mode so that i can use the extra IAT correction with it.
    It worked today, it takes the richest it seems.
    Oct 2005
    Ok cool. Does A00014 not work properly while in PE?
  1. BBL Auto Restart After Entering "Power Saving" Mode?
    By swingtan in forum Black Box Logging
    Last Post: March 8th, 2011, 08:52 PM
  2. PE mode
    By turbo lcc in forum Gen III V8 Specific
    Last Post: January 29th, 2007, 02:34 AM
  3. PE mode
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: September 22nd, 2006, 01:18 AM
  4. PE mode lag
    By Draco in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2006, 10:21 AM
  5. Can Valet mode be used to turn SD mode off and on?
    By ForcedC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 10:53 AM
