Results 1 to 10 of 14
Thread: PIDs: noob questions here
    Jan 2013
    Default PIDs: noob questions here
    what are PIDs? where do i select them? when do i use them? how many can/do i use? which ones should i use? im a complete noob in the tuning world so i need to learn the Cummins specific basics!
    PIDs (or in the case of Cummins PID groups until EDA comes out) are the parameters to log data from the ECM. Think RPM, speed, injection pulsewidth/quantity, boost, MAP, etc.
    You need, no you MUST, have a strong knowledge of PIDs and logging BEFORE attempting to tune ANYTHING. If you dont know how your truck is doing bone stock and start making changes, how will you know if your changes are good or bad?
    Jan 2012
    07.5 Mega stock
    00' EX-Cab MFI
    Jan 2013
    ya this is what im trying to learn. so what groups of PIDs should i select? which apply to logging and tuning the cummins engine?
    Senior Member WyoFreeride's Avatar
    Sep 2011
    Start by reading and doing this, Rich has some very useful tutorials that will help you out, there are also a couple videos I've seen, either on CF or CompD, can't remember. It also would be a good idea to get the tuning books from Starlight Diesel if you can't afford or don't have time to go to one of his classes. Zach has done a good job at putting a lot of very useful information in one place, and they aren't too expensive, especially considering the possible damage you can do if you don't know what you are doing.
    2010 Dodge QCSB 6.7 Auto
    Jan 2013
    ok so ive read the tutorial and have selected the "recommended" PID groups i connect to my truck and start to log data but i only can see real time data under the data tab. my dashboard wont show real time data and i dont know why? is there something i need to do? also what i found weird is under the data tab it was showing a real time boost pressure of 13 psi at idle!!???? whats up with that?
    Senior Member KhakiCummins's Avatar
    Sep 2011
    the sensor reads absolute pressure not gauge pressure. At sea level, the sensor would read about 14.7 PSI at 0 boost so you will always need to subtract whatever your atmospheric pressure is from you sensor reading to get Boost. Not sure where you are at but I'm assuming that you are at a couple thousand feet altitude and that is whey you are reading 13 psi with 0 psi of boost.
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
    Jan 2013
    Quote Originally Posted by KhakiCummins View Post
    ahh ok thanks for that info! now what about why can i only view real time data logging fromm the data menu rather than the dashboard?
    Jan 2012
    Are you recording while looking at the dashboard?
    07.5 Mega stock
    00' EX-Cab MFI
    Jan 2013
    Quote Originally Posted by Robs24vCTD View Post
    Ya I selected my PIDs and truck is Running I press the record icon and under the data tab it is recording live but when I click on the dashboard
    tab nothing is recording?? None of the gages show anything working
  1. noob, help please
    By techrunner in forum Gen III V8 Specific
    Last Post: July 30th, 2011, 12:55 PM
  2. noob needs help
    By mgarfias in forum Gen III V8 Specific
    Last Post: April 19th, 2011, 06:10 AM
  3. Yet another Noob with questions
    By kjhansen in forum EFILive V4
    Last Post: March 26th, 2008, 11:31 AM
  4. Noob questions ?
    By RPO_Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2006, 11:01 AM
  5. IAC PIDS Questions???
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 2nd, 2005, 08:35 AM
