Results 1 to 7 of 7
Thread: P0102
    Mar 2013
    Default P0102
    Hey guys I need a little help.
    I had an EGR block plate installed today (LMM. Yes, it was a pain to do and I paid dearly). I drove the truck about 20 miles and the check engine light came on. At that time I had not installed the EFILIve so I don't know why the light was on.
    I then installed the EFIlive and the light went off. I used the DSPstock tunes which are for all emission stuff still in place.
    I drove the truck about 20 miles and when I returned to my house and sitting in the driveway the light came on again. This time I used the AutoCal to scan it and it had the code P0102. Does this have anything to do with the egr block plate and running the DSP stock tune tune?
    Anything I need to check / fix or do to turn the light off?
    I do have a down pipe back exhaust to install, but haven't yet. Will installing it and switching to the race tune clear the code and turn off the check engine light?
    Thanks for you help!
    Scott
    aka Rabbit.
    Rabbit
    Hi Scott,
    This sounds like something you need to discuss directly with your tuner. He/she built the tunes for a specific purpose and we (public) have no idea what that is. Usually AutoCal files get locked when they are saved for use with an AutoCal.
    Mar 2013
    Thanks Erik.
    ATP is where it came from. I'll give them a call tomorrow!
    Rabbit
    Quote Originally Posted by Rabbit View Post
    Thanks Erik.
    Sure thing, wish I could help more but all we can do on here is troubleshoot some connection issues, firmware updated, etc issues. AutoCals are really designed to be supported by the tuner that sells them, fortunately they're pretty easy to use!
    Moved to Diesel/LMM section.
    Mar 2009
    P0102 is semi common with the BOSCH ECM and a DSP5 tune. Was it a P0102 code that popped before you put the tune in? If it was then it sounds like you didn't get your air box or your intake duct sealed back up properly when you pulled it off to get in and do the blocker plate. P0102 is for low airflow at teh MAF sensor which on a stock truck is normally common when your intake box/resonator(black box on top of the turbo that hooks into your intake) is cracked or leaking. It could also be because you didn't get your PCV hose hooked back up properly. Basically it means there is an air leak allowing un measured air into the engine.
    Mar 2013
    Quote Originally Posted by THEFERMANATOR View Post
    Yes, the code came up before the EFI live was installed. I have taken everything apart and put back together to make sure it was sealed up tight. Nothing has worked.
    I can clear the code out and it pops back up after 60- 70 miles.
    Rabbit
  1. P0102
    By Grey Silver in forum Gen III V8 Specific
    Last Post: August 25th, 2008, 05:37 PM
  2. causes of p0102
    By Kurtomac in forum Gen III V8 Specific
    Last Post: July 21st, 2008, 01:59 PM
  3. P0102 and P0153
    Last Post: July 10th, 2008, 04:03 AM
  4. P0102
    By caver in forum General (Petrol, Gas, Ethanol)
    Last Post: September 12th, 2005, 07:56 AM
