Well folks, every time I take the truck down the track I end up with an overvolt code from the MAF p0103. Looking at the MAF Flow Rate, Analog table in EFI live I believe I have found said issue but I was hoping for some confirmation. As you can see in the table at 4.84 volts i'm getting a maf flow rate of 602.39, then at 5 volts I have a corresponding 681.58 maf flow rate. I believe the problem is arising from the drop after this showing 5.0 volts all the way down the table registering with a 477.78 grams per second flow rate. Please see the picture below for a clear view of what I'm talking about. Any input is appreciated, thanks gentlemen.
Edit: Running sdp twins, s475 over stock.
