Page 1 of 11 123 ... LastLast
Results 1 to 10 of 109
Thread: Possible ways of tuning the LML?
    Mar 2009
    Default Possible ways of tuning the LML?
    I know it has been discussed that and said that the LML ECM can no longer be read out due to the new coding in the ECM that prevents reading. What about using a ROADRUNNER type set-up installed into the ECM? I see MOATES is still selling them on there site, and thought that maybe this could be a way of doing this. Or what about getting some tuners in the states equipped to open the ECM physically and read out the tune, then they could in turn put the tune on a flash drive or something and send it back to the customer for tuning? This would still allow the owner of the vehicle to use HIS tune out of his ECM, but he would have a copy of it that he could now adjust accordingly and then flash into his truck. I'm not trying to open a can of worms here, just trying to throw ideas as I know ALOT of LML owners would really like to be able to use EFILIVE on there new trucks to make them exactly how they want them.
    You probably need to search the internet on BMW EDC17 and see just what all the fuss is about when it comes to this ECM.
    Here's a good start: http://www.cmdtec.it/prod_bootMEDC17.asp
    You also need to appreciate that at some point it just becomes too hard and we need to move on to other more accessible platforms, I know EFILive is not alone here. Sure you might feel that EFILive has abandoned LML owners, but please, it wasn't us that stuck that ECM in the truck. Also, the LML ECM cannot be ordered through GM, they won't sell them to you, so I sure would not be putting my hand up to be pulling them apart to use something like that CMD box on one.
    Finally, the flash memory is internal in the CPU, there is nothing a Road Runner type device could connect on to.
    This ECM was designed to stop tuners, simple as that.
    May 2010
    This ECM was designed to stop tuners, simple as that.[/QUOTE] Do you fear at all that the manufactures will make this more of a trend in the future? Not just diesels but gas as well?
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    Mar 2009
    I'm not up to date on much involving the EDC17 ECM, just had a thought that I thought might allow EFILIVE to expand into a market that many people want. I understand from a business perspective you have to do what is most beneficial to your company though. I have no dog in this fight per say as I'm still old school LB7 DELPHI ECM.
    Quote Originally Posted by slows10 View Post
    Not for a few years on the gas stuff. GM has moved away from Bosch on the gas cars back to in-house designs so the horrors of what Bosch can do are gone.
    None of this would be an issue if we could execute our own bootloader on the Bosch ECM's, but you can't, so whatever they say must go.
    Quote Originally Posted by THEFERMANATOR View Post
    There is the legalities of it too, someone at GM is going to ask the question on how these trucks are being tuned when the program cannot be read out of them.
    Dec 2006
    It was mega gay of GM to do that. Blame them. So sad
    - Roland
    GM dealer tech since 2005
    '01 Z28 LS1/T56
    t-tops :usa:
    stock 241 heads, stock cam,
    stock muffler, factory wheels
    8.2 @ 86
    (1/8th mile with 255 Toyo Proxes)
    I am learning...
    Mar 2009
    I also see GM's point of view on this subject as well. look at what happened with FORD and the 6.0L. How many of the 6.0L problems were due to tuners and such that pushed the engine over the edge and then those people would go to the dealership expecting it to get fixed. FORD would see that it had been modified with aftermarket performance parts and void the warranty and stick teh customer with the bill as they rightly should(you play you pay). So the customer now badmouths FORD every chance he gets saying how they make a POS, when the problem was brought on because of teh customers addition of performance parts. In the end the customer gets a HUGE bill or a broken truck, and FORD got a HUG black eye and bad publicity. I realize not all of the 6.0L PS problems were due to adding power, but a large portion of them were. GM just decided to go one step furthur beyond there old methods of trace files to keep tabs, and blocked the ECM to cut people off at the pass. Yes it angers some owners who want more power, but in the end it can keep GM from getting a black eye from limped ALLISONS and engine repairs.
    Theres 2 sides to every situation.
    FORD Australia have flash counters in their ECM's for the Turbo 6 gas motor they do out here, I'm told by someone at a FORD dealership it's caught plenty of false warranty claims. So yeah, I see GM's side of it as far as that goes, but, not everyone thinks like that either.
    Dec 2006
    Agree with both of you, but consider this: The '01 - '10 Duramax and Allison has been modified extensively, yet NO ONE is bad mouthing the quality of those, or GM for not covering obvious racing damage. Ford should have made a better quality product with the 6.0. I know there are many Allisons that have been limped or destroyed, but customers understand it's because the power is doubled, and the engines are still not blowing up left and right. I always gave GM tremendous credit for building products that were reasonably reliable even severely modded, and now I say: gay move GM lol but I understand. People love performance and modding. My 63 year or stepfather has a build LMM, and he will never buy and LML...
    - Roland
    '01 Z28 LS1/T56
    t-tops :usa:
    8.2 @ 86
    I am learning...
    Quote Originally Posted by Boost View Post
    Unfortunately GM probably don't view their trucks as 'performance' vehicles and the accountants want to stop warranty claims. As long as the Duramax continues to use the Bosch EDC17 then I can't see anything changing.
  1. 2011 LML Duramax Tuning Please.
    By duramaximizer in forum Diesel
    Last Post: April 28th, 2011, 09:18 AM
  2. Lml / lgh
    By shay in forum Duramax 2011+ LML / LGH
    Last Post: March 10th, 2011, 12:41 PM
  3. LML TCM Tune
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: November 15th, 2010, 04:52 PM
  4. Emission Testing/Ways to Cheat?
    By onegonewild in forum Gen III V8 Specific
    Last Post: July 13th, 2009, 06:08 AM
  5. Tuning for Economy can be done several ways.
    By wait4me in forum Tuning For Economy
    Last Post: March 19th, 2008, 01:31 PM
