Results 1 to 7 of 7
Thread: editing a pid calc
    Lifetime Member johnv's Avatar
    Jan 2005
    Default editing a pid calc
    Ok,,
    I've just worked out a new error corrected slope and intercept for my wide band analog voltage output (LM1) new slope 1.994012
    new intercept 9.943186
    so how do I edit the PLX calc formular to correct this ?
    You should create a new PID in \My Documents\EFILive\V7\User configuration\calc_pids.txt, see attached calc_pids.txt file.
    You can also set up your own system name (in this case O2-Wide-JV) so that your PIDs show up in their own section - making them easier to find.
    Jan 2005
    Thanks Blacky,
    PLX o volts = 10 afr
    5 volts = 20 afr
    I worked the slope and intercept out for this, am I correct in noteing that your calc is based on 0 = 10
    5 = 30
    so I just change the 30 to 20 in the calc ?
    Cheers
    John
    In the calc_pids.txt, the 10 and 30 are the "Low" and "High" values used to set the low and high values on a chart y-axis or the low and high tickmarks on a gauge; they are for chart/gauge display only and do not affect the calculation as defined under the "Expression" column.
    Jan 2005
    OK thanks for clearing that up
    You should probably change the 30 to 20 since the chart will never display above 20.
    Jan 2005
    Done and all works great thanks Paul
  1. Editing Filters
    By mistermike in forum General
    Last Post: July 8th, 2009, 12:43 AM
  2. Editing log files
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2008, 04:55 AM
  3. First Try and Editing A Tune
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 22nd, 2007, 03:41 PM
