Results 1 to 2 of 2
Thread: 04 LB7 won't full flash and $0537 error code
    Mar 2013
    Question 04 LB7 won't full flash and $0537 error code
    My auto cal won't flash my ECM it keeps saying wait 10 seconds and then flickers saying trying to connect, it does this for about a minute and then I get a $0537 code. Also my security light is on but the truck still runs and drives like normal. And another thing is that whatever caused my security light to come on it locked in my old PPE tuner which I can't get back to stock so I'm trying to overwrite it. I need some help on this please!
    Nov 2005
    From our error code list.
    $0537 Controller is locked with a custom key.
    An attempt was made to read or program a controller that cannot be unlocked using the standard GM keys.
    If you know the key that was used to lock the controller, please use the unlock option in the EFILive software to unlock the controller before attempting to read or re-flash the controller again.
    I would suggest that a previous programmer used a custom key to lock your ECM to protect their tuning information. You'll need that to unlock your ECM for tuning.
    Cheers
    Cindy
  1. Replies: 9
    Last Post: January 30th, 2013, 03:37 PM
  2. 07 lbz full flash now error message
    By 07redmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 27th, 2013, 02:59 AM
  3. Error #07 lb7 won't scan?
    By _nar_ in forum General (Diesel)
    Last Post: August 19th, 2012, 07:35 PM
  4. Full flash gone wrong truck won't start !!!!
    By Collins in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2012, 10:18 AM
  5. LBZ Full flash update error...
    By 06Dmaxpwr in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 15th, 2008, 08:42 PM
