I'm trying to understand why commanded AFR is 14.7, wideband is reporting 13.8 while LTFTs are +15%. The INJPW is at the minimum 1.3ms setting. Are the B1204 small pulse adders or B1210 Injector correction tables adding to the fuel trims?
My changes have been to the B1203 Min pulse and B1210 correction tables. Trying to address a high spike in my VE tables at cruise.
2005 E40 LS2 GTO running the boost OS.
