Hello, everyone... this is my first post here although I've been a long-time lurker.
I've been active on the PPE GM Truck forum for many years, and we've been working on a solution to the 98-99 GMT400 vibrating fuel gauge issue. We've managed to come up with a permanent solution to this problem, but it does require re-scaling the PWM fuel gauge table in the calibration. Having only recently purchased EFILive, I am now looking to do exactly this, and get the fuel gauge repaired on a 99 Tahoe once and for all. But, I've hit a snag.
The OS loaded into the blackbox PCM on this 99 Tahoe I'm working on is #09365085 with a fuel system calibration #9351032, and it does NOT show the field required to re-scale the commanded PWM signal for the gauge. It only shows fuel tank capacity. However, when I open up an Express Van (411 PCM for L31) tune with an OS #12212156 and fuel system calibration #16264666, there is a table (F0501) wherein the commanded PWM can be adjusted. I am using V2 with the latest software and hardware updates, but I cannot find table F0501 in the blackbox calibration.
Another member on the PPE forum has already done this with success on his Tahoe (so I know the table is there in the blackbox calibration) , but he is using HPTuners (screenshots are posted in the thread). Is there any way I can get EFILive to display this table? I'm really close to getting this problem solved if I can just get this table re-scaled.
I don't know if forum etiquette here frowns on linking to other forums, but (if permissable) I can provide a link to the thread where all this is thoroughly discussed if anyone wants to see what I'm talking about.
