Results 1 to 4 of 4
Thread: LBZ bench harness wiring diagram
    Mar 2013
    Default LBZ bench harness wiring diagram
    Hello,
    I have just about got all my parts together for building my bench harness for programming my spare ecm and tcm for my truck.
    Just seem to be having a brain fart or something as I have all the info on pin position etc and what pins require battery power and switched power, but my brain can't work out from the EFI live bench harness PDF which wires go to the OBD connector for the CAN + and Can -
    I am assuming pin 6 on the OBD connector is CAN + (EFI PDF says HI)and pin 14 is CAN - (efi pdf says LO)
    Someone just poke me with a stick and it will click
    Last edited by boothybunch; March 17th, 2013 at 05:50 AM. Reason: dick caught in zip
    Mar 2013
    Any takers???
    Can+ = high, Can- = low AFAIK.
    I just used that .pdf, you should be good.
    Mar 2013
    that's all I needed to know.
    Now to break out the BFH
  1. PCM Bench Harness Wiring diagrams
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2015, 05:51 PM
  2. LBZ standalone harness....is there any reason to keep the Class 2/J1850 wiring?
    By DURAtotheMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 16th, 2013, 03:59 PM
  3. VX-VY 5.7 wiring diagram
    By shane in forum Gen III V8 Specific
    Last Post: September 24th, 2009, 02:59 PM
  4. LBZ/LLY Bench Harness
    By Dream8000 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 14th, 2007, 03:13 AM
  5. E38 (06 Ls2) Bench Harness Diagram-help?!
    By Chuck CoW in forum General (Petrol, Gas, Ethanol)
    Last Post: June 15th, 2006, 11:19 AM
