Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: VE Tuning w/o Wideband?
    Feb 2013
    Default VE Tuning w/o Wideband?
    Is it possible to do some rough VE tuning without a wideband? The VE tutorials I've read all require a wideband. I'm trying to dial in my tune at idle just to get this thing to pass smog. Right now it's putting out 36% too much HC at idle, but is 92% under the HC limit at 2500 RPM. It is also misfiring slightly at idle which is probably the issue. I'll get a P0300 after a couple minutes of idling. The misfires are spread out evenly across the cylinders. The tune is stock at the moment.
    2001 Silverado 5.3L ECSB 2WD T56:
    T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
    EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
    Ok, so you have a cam but havent tuned it at all? You NEED a wideband, like go buy one tomorrow. If you mod the engine at all, you need to adjust the VE/MAF tables and Im frankly surprised your engine runs on the stock tune with a cam. You could be super lean at idle which is causing your excessive HC and your misfire.
    You can try doing Calc.VE using LTFTs, its ok for a rough (really rough) start.
    I apologize if I sound like a jerk, but you really need to get a WBO2 on it asap. You can rough in a VE/MAF table using Calc.VET in a few hours tops, be done with all of it and pass emissions.
    Feb 2013
    Thanks for the tips. I do have a wideband, but it's not installed yet. I'm hoping to get this thing to pass without spending money and time modding my stock exhaust system or doing in depth tuning. In a couple weeks when the turbo goes on everything will change, hence not wanting to put too much effort into it. The wideband will go on with the turbo.
    The cam isn't all that big. It runs great other than the misfire issue. But I do baby it around as I know the stock tune is not ideal.
    I'll try and do the Calc.VE using the tutorial.
    If you're getting misfires at idle, you may be overly lean or overly rich...
    unburnt fuel means that unburnt oxygen is present, the NBO2 sensors see this as lean, so the PCM keeps adding fuel (too much fuel).
    Or there may be other causes of misfire (coolant leak).
    At idle, the PCM may be using either of MAF or VE.
    Using the scantool->tunetool cursor linking feature can you determine which cells in the various tables are being referenced (B0101, B3605, B5001).
    Try changing the O2 mV switch points.
    Feb 2013
    What do you suggest for O2 switch points? The only thing I've read is to set them all to 450 mv.
    My O2 activity at idle is not pretty, they appear to be lazy as you have mentioned before. My guess is they are acting lazy because of the misfires.
    And what about idle timing? Right now my base table is calling for 18 deg at idle. It varies fairly erratically at idle, from 9 to 24 deg. Tomorrow I may try to add timing using Bidi and see if it helps the misfires. If I fix the timing at idle then it starts to surge +-150 RPM from commanded.
    I understand not wanting to spend a lot of time before turbo'ing, but the solutions is pretty simple: spend the 2-3 hours, Calc.VET it, pass emmissions.
    Id do that, then once you have the A/F done you can tweak spark timing at idle.
    Sometimes the only way is the way we've been avoiding, you're going to spend more time trying not to tune it than if just tune it and being done with it.
    Quote Originally Posted by ferocity02 View Post
    Possibly, or, the O2 activity may be causing the misfires.
    Try timing and see what happens to misfires (good idea), and if you now get surging, the you will need to tune in this area.
    More info:
    Feb 2013
    Did one round of CalcVE this morning as a practice. Seems to be working okay. Should I be resetting the LTFT's before starting?
    I also messed with the timing at idle and found that reducing the timing for the most part eliminates the idle misfires. My base table calls for 18 deg at idle. Using DVT I subtracted ~10 deg and the misfires went away. It seems to be able to maintain the commanded idle speed better as well, +-20 RPM at the most. Before it was +-50 RPM. The exhaust smells noticeably better too. The idle sounds rougher and deeper with the reduced timing. Any downside to running the idle timing this low? Research shows people running 20-30 deg timing at idle.
    Yes, reset LTFTs between log/tune sessions.
    Not sure on idle timing, really more of what your engine likes.
    Feb 2013
    Ok, I've been reading Calc.VET threads up the wazoo... lots of useful information but I wish it was all in one place for easy reference. Again, I'm doing this without a wideband just to get the VE table roughly close enough to pass smog. Do these steps sound correct, assuming the calc pids and maps have been correctly setup?
    Tune mods:
    1. B0701: Disable Catalytic Converter Protection
    Insures accurate stoich and PE mode/WOT Fueling
    During tuning only
    2. B0120: Change RPM Threshold for Airflow Calculation from 4000 to 400
    Eliminates any Airflow Correction from the VE Table
    During tuning only
    3. B3308: Disable DFCO: Change B3308 (M6) to 140C Change B3313 to 140C
    Accurate fueling computations
    During tuning only
    4. B4105: O2 Switch-points to 450 Millivolts
    Smoother MAF & VE Table
    Permanent
    5. B3618: PE Modifier Based on Rpm (EQ): 1.16
    Safe adequate Fueling regardless of Fuel Type
    Permanent
    6. B3616: PE Enable: make sure PE enables as load becomes significant
    (e.g. below 60% TP below 3200 rpm, 35% TP above 3200 rpm).
    Permanent
    7. B3608 and B3609: PE Delay: set these to zeros.
    Permanent
    Logging:
    Reset LTFT's before logging
    Log data
    Filter data to exclude for ECT, low cell count, high TP% change
    Adjusting tune:
    Copy and paste calculated VE table into B0101
    Smooth table
    Copy and paste (multiply) calculated LTFTBEN table to B5001
    Smooth table
    Repeat logging and adjusting tune steps until B0101 and B5001 aren't changing much. Revert tune changes 1-3 back to original values.
  1. trying to do a little fine tuning with no wideband
    By loganlewis in forum Gen III V8 Specific
    Last Post: October 25th, 2012, 09:04 AM
  2. wideband O2's and Auto VE tuning
    By harascho in forum General (Petrol, Gas, Ethanol)
    Last Post: March 22nd, 2009, 08:44 AM
  3. tuning with wideband O2
    By ExtTB in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: January 10th, 2008, 06:29 PM
  4. tuning vehicle not using any wideband
    By dsmlights in forum Gen III V8 Specific
    Last Post: December 7th, 2007, 01:16 AM
  5. Tuning friends truck...need ideas about wideband
    By MrZ71man in forum General (Petrol, Gas, Ethanol)
    Last Post: October 28th, 2007, 06:02 AM
