Results 1 to 4 of 4
Thread: When entering data on my 2007 Yukon Denali how do I get PIDS that relate to my engine
    Jan 2013
    Default When entering data on my 2007 Yukon Denali how do I get PIDS that relate to my engine
    When I enter the serial number, gross weight, engine, there is no selection for the 6.2l engine. Only 6.0l and 8.1l. How can I get this changed for correct engine displacement and PIDS for logging. I'm ready for some data logging. Also I am wondering do i need to purchase and hook up a eternal o2 sensor to do my vve or is there a method where I can utilize the trucks o2 sensors.
    2007 6.2l 376ci, Ported heads, comp cam 156-403-13, Air raid cold air intake, Jet mass air( not in use because still set up in SD mode), more up-grades to come.
    Have the truck running and idling good and am ready to do vve, ect.
    Jan 2013
    PS. Using EFI Live V2 here. Not sure how to paste tune and logs.
    Scan tool: Edit->Validate PIDs will give you the supported PIDs for your vehicle.
    Jan 2013
    Thanks that worked.
  1. 2006 gmc yukon denali xl
    By JST in forum Petrol / Gas
    Last Post: June 25th, 2011, 12:01 PM
  2. EBCM setup / '03 Yukon Denali
    By Boost in forum Gen III V8 Specific
    Last Post: December 17th, 2009, 04:03 AM
  3. Looking for some data from a stock engine log
    Last Post: June 24th, 2008, 03:14 AM
  4. 2007 yukon pcm
    By wygren in forum General (Petrol, Gas, Ethanol)
    Last Post: September 13th, 2006, 03:49 PM
  5. Not entering PE Mode
    By oztracktuning in forum Custom Operating Systems
    Last Post: March 21st, 2006, 01:35 AM
