Results 1 to 7 of 7
Thread: Flashing OS into a brand new 2006 LBZ ECM with EFILive
    Mar 2013
    Default Flashing OS into a brand new 2006 LBZ ECM with EFILive
    Hi new to the whole efilive thing and was wondering if it is possible to flash in the correct LBZ OS into a brand new 06 LBZ ecm instead of using a tech2 with efilive? sorry if this sounds silly but this is my first time using efilive after getting it off a friend who no longer needed it
    Mar 2009
    Works just fine. Just make sure and do a full flash when you do it. When your done there is a few other steps that you need to do since it is a new ECM. You need to go in and copy the injector flow data from the GPCM to the ECM, and you may have to reset the security system afterwards.
    Mar 2013
    awesome thanks for the help now to give it a try are there any walk throughs and also will i have to register it with efilive?
    Mar 2009
    Yes, you will have to license the new ECM to your cable as the VIN licenses are licensed to the serial number in the ECM and not the VIN number. As far as flashing it, get your tune and full flash it in. You may have to go in and do a security learn as some ECM's are set to learn the BCM and others are not. And it is a good idea to transfer the injector flow data fro mthe glow plug controller to the new ECM so features like your remote start can work if you have it.
    Mar 2013
    thanks a heap man my next question is i think iv got the correct ecm was suppost to be here is the part number on it can anyone tell me if this will run my lbz duramax please the service number is
    #12609441
    Thanks again
    Mar 2013
    any body please?
    Dec 2005
    12606127 is the correct number for an lbz
    www.mscservices.net
  1. Lmm and Lbz problems flashing. All Figured out
    By dieselguy9311 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 15th, 2013, 08:02 PM
  2. Writing to a brand spanking new E37 ECM
    By engimuneer in forum E37, E38 & E67 PFI ECM's
    Last Post: December 16th, 2011, 10:58 AM
  3. Need LBZ ecm, willing to give immacculate LMM ecm as exchange
    By badassmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 9th, 2011, 04:20 AM
  4. 2006 LBZ TCM file needed
    By Xman in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 2nd, 2010, 08:06 AM
  5. cant read 2006 lbz allison tcm
    By mrrattle in forum FlashScan V2 BB Logging
    Last Post: February 27th, 2008, 04:31 PM
