Results 1 to 7 of 7
Thread: Desired Idle Airflow
    Feb 2013
    Default Desired Idle Airflow
    Quick question here about desired idle airflow. Why is this parameter available for the user to modify? It seems like the engine should take in whatever air it needs to maintain the desired idle speed, and then adjust fuel to maintain stoich. Seems like idle is "overdefined".
    Lets say the engine needs 8 g/s at idle. What happens if the desired airflow table says like 5 g/s, or 12 g/s?
    I tried doing RAFIG but the resulting desired airflow values were greater than what the MAF says. So instead I just copied the MAF vs ECT data into the desired airflow table.
    Thanks!
    2001 Silverado 5.3L ECSB 2WD T56:
    T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
    EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
    Feb 2013
    As a followup question... Is the purpose of dialing in the idle desired airflow table to get it pretty close to correct, and then relying on the idle trims to get it exact?
    I noticed the idle trims can max out if the desired airflow is way off. I also noticed some inconsistency when logging MAF flow at idle. If I let it sit and fully warm up, the hot idle MAF flow would usually be ~0.5 g/s more than if I drove for awhile and then measured the hot idle MAF flow.
    Feb 2013
    Well today I learned that too high of a desired airflow will give you a hanging idle when moving. Seems like throttle cracker airflow + idle desired airflow gives the idle airflow when moving.
    My idle desired airflow is turned up because I turned down my idle timing for smog. I did not adjust the throttle cracker accordingly.
    Lifetime Member macca_779's Avatar
    Jan 2007
    Desired is like the base airflow. Add cracker and yes it will hang if you have to much as trims aren't used in a non idle condition. I increase desired above what rafig generated because when reversing mine would drop low. I don't use cracker at all except in the 400rpm row as a stall saver.
    Feb 2013
    Quote Originally Posted by macca_779 View Post
    Good info. I knocked 75% off the throttle cracker airflow and it is much improved. I have tried turning cracker off, but it would surge and try to die when rolling in neutral. I'm confused as to what's different between rolling idle and stationary idle. Are you suggesting it's not actually in idle mode when rolling in neutral with the throttle closed?
    Jan 2007
    Quote Originally Posted by ferocity02 View Post
    No because you have the speed enabler in preferences which allows idle mode to kick in
    Feb 2013
    What would happen if I set the speed enable such that it was always in idle mode when the throttle is closed, rolling or not, and then disabled throttle cracker?
  1. DCFO Minimum idle airflow desired Coastdown speed
    By The Alchemist in forum E37, E38 & E67 PFI ECM's
    Last Post: July 28th, 2015, 07:47 AM
  2. Any way to scan Desired Idle airflow?
    By Highlander in forum Gen IV V8 Specific
    Last Post: August 19th, 2009, 09:20 AM
  3. Desired airflow won't equal measured airflow
    By Ryan in forum Gen III V8 Specific
    Last Post: June 4th, 2008, 08:17 AM
  4. Desired Airflow
    By Thumper in forum Gen III V8 Specific
    Last Post: April 23rd, 2008, 01:23 AM
  5. Desired Idle Speed and Idle Airflow
    By Bowtieman in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2006, 10:07 AM
