Results 11 to 20 of 26
Thread: V7.5 & V8 software ?
  1. #11
    Jun 2012
    With the EFILive V7.5.7 Build 211 and Download EFILive V8.2.1 Build 203 the screen look different.
Name:	BBL controller.jpg
ID:	14771Click image for larger version.
Name:	BBL controller T43.jpg
ID:	14772Click image for larger version.
Name:	BBL Firmware.jpg
    "BLACK"-2007 Yukon Denali 6.2 gasser EFI AutoCal
    "BLACK"-2007.5 GMC Sierra 3500HD SRW, LMM Dmax, EFI AutoCal/Spade
  2. #12
    Try without the T43.
  3. #13
    Jun 2012
    Ok, thanks I'll try that this weekend.
    I guess I gave you the redneck version of a snapshot, my computer minded son told me I can snapshot the page from my monitor for my computer then copy and paste.
    I'm learning but @ a slow pase.
  4. #14
    No worries
  5. #15
    Jun 2012
    Default Slected PID's still not able to view on AutoCal
    joecar,
    I took out the T43, now only 38 is selected with 12 pid's, it still will NOT show any pid's to view.
    I scrolled down to "Select Pid's" (ok) then 38 shows (ok) then it goes directly to "Record Data" when I hit (ok) it starts scanner time counting.
    The AutoCal will save the recorded data but that is all it will do besides the tuning.
    I know the AutoCal is a little limited on space could my tunes installed be affecting PID viewing ?
    I have 4 tunes installed, 38 mod coz file, 38 stock coz file, T43 mod ctz file, T43 stock coz file, my tuner has not done a coz file on the T43 mod.
    I'm not comfortable with only having the stock files on the computer and putting only the mod files on the AutoCal, I'm concerned about possible computer issues and loosing them.
    ?, I have a AutoCal setting around that I am not using anymore, if I took the tune files off of the AutoCal I'm not using anymore could it be used as a scanner on other vehicles ?
    That is if my problem with viewing PID's is because of the tuning space I'm using on the AutoCals that I am using now.
    I do thank you for taking the time to try to help me solve this.
    Also, I'm including another RedNeck snapshot of what's in my AutoCal, I tried the proper way but could not figure it out.
Name:	BBX-BBL 3-25-13.jpg
ID:	14779 Heres the bootblock and Firmware #'s Click image for larger version.
Name:	Bootblock and Firmware.jpg
  6. #16
    Jun 2012
    joecar,
    I just re-configured my spare AutoCal (that I'm not using) to read only engine 38 and only one pid MAF g/s and it does not show pid's either on my gasser ?
  7. #17
    Can you post the Options.txt saved from the BBx window.
  8. #18
    Jun 2012
    BBX saved files saved ctrl s.txt
    I'm not sure if this is what your looking for, I had the AutoCal plugged in and went from there.
    If I'm reading it right it looks like nothing is Y for the PID's even though they show on the selected pid screen and I did programmed them in.
    E38 is the only engine that shows active Y and that's what I selected.
  9. #19
    Quote Originally Posted by RVDAN View Post
    I tested your file here and it appears to work ok. I removed the AFRATIO_M PID since it was not supported on my test E38 controller.
    When the AutoCal is showing the time counting, press the "Next" button to sroll down thru each PID, press the "Prev" button to scroll back up, eventually getting to "Exit" at which stage pressing OK will stop the data log.
  10. #20
    Jun 2012
    I was never told to view the select PID worked the way you explained, thank you.
    So when I scroll down after the time is counting on the data log I will see the PID's and be able to read whats going on.
    Like MAF g/s at idle or while driving or any of the other PID's on the list?
    I check this out tomorrow morning, I do hope this works I'm worn out trying to figure out what the issue was.
    THANK YOU
  1. Replies: 1
    Last Post: June 29th, 2011, 09:39 AM
  2. Replies: 8
    Last Post: February 18th, 2010, 10:30 AM
  3. 2009 E38 & E67, software update required
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: January 15th, 2009, 05:55 PM
  4. WtB junk pcm & red & blue connector to buld a 97/98 to 99/04 harnes
    By Treurentner in forum Gen III V8 Specific
    Last Post: July 19th, 2007, 03:58 AM
