Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: V7.5 & V8 software ?
  1. #21
    Jun 2012
    BLACKY, THANK YOU
    Yes this worked, it was suggested that I re-calibrate and do updates because something was wrong with the software trying to get the AutoCal to show selected PID's the way I was doing it.
    This has been going on since last Tuesday with no luck.
    I figured if I asked for help on the EFILive forum someone might come to the rescue.
    Thanks Again,
    This data was saved in the AutoCal all I need to do is connect my AutoCal in Explorer and delete the saved pid data so I won't have unnecessary space being used, correct.
    "BLACK"-2007 Yukon Denali 6.2 gasser EFI AutoCal
    "BLACK"-2007.5 GMC Sierra 3500HD SRW, LMM Dmax, EFI AutoCal/Spade
  2. #22
    One other thing that will save you space is to un-check all the DTC description options when configuring AutoCal for BBx duties.
    AutoCal can't show DTC descriptions so there's no use copying the DTC description files to the AutoCal device.
  3. #23
    [QUOTE=RVDAN;188950This data was saved in the AutoCal all I need to do is connect my AutoCal in Explorer and delete the saved pid data so I won't have unnecessary space being used, correct.[/QUOTE]
    Correct.
    There is also an option on the AutoCal menu that allows you to delete all scan files without having to get to a PC. Obviously if you've logged some data and want to save it to a PC then deleting them would be foolish, but if you want to start logging and realize you've forgotten to clear out the old log files that you've already saved to your PC but your PC is not close by, then you can use that option to clear the old files.
  4. #24
    Jun 2012
    Correct.
    Thanks for all the great info,
    Deleting the DTC description options dropped the Space Required down to 14%,
    Thanks again,
    Dan
  5. #25
    Quote Originally Posted by RVDAN View Post
    Thanks again,
    Dan
    Eventually all this info will be in the V8 Scan/Tune tool user manual, unfortunately the user manual is not completed yet.
  6. #26
    Jun 2012
    I don't think my 2 tuners are aware of this yet, because both felt the space required should read in the 40% range.
    Thanks,
  1. Replies: 1
    Last Post: June 29th, 2011, 09:39 AM
  2. Replies: 8
    Last Post: February 18th, 2010, 10:30 AM
  3. 2009 E38 & E67, software update required
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: January 15th, 2009, 05:55 PM
  4. WtB junk pcm & red & blue connector to buld a 97/98 to 99/04 harnes
    By Treurentner in forum Gen III V8 Specific
    Last Post: July 19th, 2007, 03:58 AM
