Results 1 to 10 of 11
Thread: just flashed in a delete only tune and throwing a p1011 code...
    Jan 2013
    Default just flashed in a delete only tune and throwing a p1011 code...
    The base file was a stock one all I did was the necessary changes for an "off road only" vehicle, flashed it in everything worked fine truck ran fine no CELs then I get on the highway punched it once and started cruising..A few seconds later i get a ding and CEL for p1011 and the truck felt like it lost a lot of power. From what I've read it has something to do with fuel pressure and or lift pump. Could this have happened because of flashing ina new tune or is it a separate problem?
    Jan 2013
    a day later and it seems like im throwing a million codes!!!! P0107 keeps coming even after i clear it, the red lightning bolt light is now on and according to the handbook that has to do with my electronic throttle control then i threw a u011a code which has something to do with my map sensor performance.... what is going on? why suddenly after a reflash am i getting all these issues? truck starts fine and voltage is normal battery cables are all tight so i dot know whats going on.. this is my DD with no more warranty so trying to avoid the stealership at all costs.
    Nov 2010
    Send me the file ill look at it and adjust dtc's accordingly to see if it's a tune issue.
    Also include a 1-min log just idling
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Jan 2013
    Quote Originally Posted by 2007 5.9 View Post
    ok i will send it when i get back home.
    Nov 2010
    You have mail.
    Les Szmidt
    2007 5.9 Dodge Ram
    Nov 2010
    Think we got it licked??
    Les Szmidt
    2007 5.9 Dodge Ram
    Jan 2013
    So far so good! Again thanks for the help. These cummins controllers are like a liberal democrat the littlest thing and they complain and throw a code haha
    Nov 2010
    Anytime.
    Les Szmidt
    2007 5.9 Dodge Ram
    Glad you guys got it fixed, can you elaborate on what the fix was? Was it a rogue DTC that needed to be disabled?
    Nov 2010
    OP had additional tuning running in parallel with EFI. Dumped that and seems to have cured the issues.
    Les Szmidt
    2007 5.9 Dodge Ram
  1. Replies: 0
    Last Post: April 17th, 2012, 12:42 AM
  2. Replies: 7
    Last Post: December 6th, 2010, 01:55 PM
  3. Throwing Code P0068
    By Picto in forum Gen III V8 Specific
    Last Post: September 20th, 2010, 12:29 PM
  4. Tow tune throwing s P0401 and P0101?
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 22nd, 2009, 04:57 AM
  5. w.b. keeps throwing a code? po1153
    By smslyguy in forum Gen III V8 Specific
    Last Post: September 24th, 2009, 03:48 AM
