Results 1 to 9 of 9
Thread: 1998 calcvet. pid list
    Oct 2010
    Default 1998 calcvet. pid list
    Trying to perform the calc.vet and only a few of the pids are avalible on my pid list. Trying to validate them any.
    Post a screenshot.
    Oct 2010
    When I try to save it to My Documents\EFILive\V7.5\User Configuration It says path does not exits. Check the path and try again. Same message every time I try to save it. Thanks bbaird
    Do you have WinXP or Win7/8...?
    In the scantool go Edit->Properties->Folders and see what folder path it says for User Configuration.
    Oct 2010
    I have 2007 windows vista. In properties folder User Confiquration C:Users\XXXXX XXXXX\EFILive\V7.5\User Configuration
    Where X's are is my name. Thanks
    Quote Originally Posted by bbaird View Post
    Copy the calc_pids.txt file to that folder.
    Also, you should be using the calc_pids.txt file containing the pid CALC.B4901.
    Oct 2005
    From post#15236(Calc.VET: correcting MAF and calculating VE) it shows DYNAIRTMP_DMA as required pid but can be replaced by CALC.B4901.
    CYLAIR_DMA and DYNCYLAIR_DMA are recommended, are there any CALC pids available to replace those for 97/98 pcm?
    97 Vette 6spd, CamMotion Titan2 LS1 cam, TSP 5.3 StageII heads, Vararam intake, Z06 manifold, ARH headers/cats, Z06 catback, Monster Stage2 clutch, 04 Z06 pcv, new style knock sensor(late98 to 04).
    Using FlashScan V1 with NGK-AFX Wide band
    Quote Originally Posted by voda1 View Post
    Try CALC.CYLAIR.
  1. CalcVET Question
    By BlackSS in forum Gen III V8 Specific
    Last Post: December 9th, 2011, 02:49 PM
  2. 1998 7.4 vortec, PID#
    By rockien in forum Vortec V6/V8 Specific
    Last Post: July 30th, 2011, 12:40 PM
  3. Convert Pass Thru Scan PID list to BBL PID list
    By jrh in forum FlashScan V2 BB Logging
    Last Post: July 5th, 2011, 08:09 AM
  4. how to get my pid list to v2?
    By 2004gmc in forum Lounge
    Last Post: May 30th, 2009, 10:52 AM
  5. IAC_xxxxx_DMA PID support for 1998 PCMs
    By jnorris in forum General
    Last Post: December 4th, 2005, 04:50 PM
