Results 11 to 20 of 26
Thread: EFILive RC 2 (March 28, 2013)
  1. #11
    Pics no worky,
    Really, I can even see them in your reply.
    and I figured, thought they were 1.8L guys? Still, probably not a lot of desire unless someone just wants the fueling cleaned up a tad, a hair more spark, and fix the trans.
    Yeah, they aren't just used on the 1.2L, actually I noticed it's possibly used on a 1.0L engine in Europe too, what a beast!
    Should have some results from some E83 ECM tuning tests soon, we know the flashing etc is all fine, has been for a while, it's just how well the engines respond.
  2. #12
    I can't see them either. Had to click reply to post and could see them in the quoted part of my reply.
  3. #13
    Weird, I use Chrome and had to actually copy the links, open IE, then paste into the browser and they would show up.
    1L and 1.2L, big displacement big power engines! LOL
  4. #14
    Pics...!? I don't see any pics (even if I click on Reply With Quote).
  5. #15
    Senior Member Behold's Avatar
    Apr 2010
    Liking the speed of the v8 tool. Shame you can select/deselect PIDS faster. Bit of a trawl unless I'm doing it wrong. Also zoom buttons would be good rather than using the menu.
    Otherwise it works smoothly and great for manipulating a small selection,
    Top work
    Thanks Antony
    Holden Commodore GTS - LS1 5.7
    12 rib Crank Driven Vortech V2 Centri Charger (Intercooled) 9 PSI.
    LS6 Intake
    LS6 Heads
    YT 1.7 Roller Rockers
    BTR Dual Spring with Ti retainers
    BTR Hardend 7.400 Push rods
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    PCM LS1B with 512KB Running COS5 v01290005
  6. #16
    Quote Originally Posted by Behold View Post
    Top work
    Keyboard hotkeys for zooming (Ctrl+Alt+I and Ctrl+Alt+O)
    Right-click on chart axis to select PIDs
    Or use mouse scroll wheel (with and without the Ctrl key pressed to scroll and zoom respectively) when mouse is over the desired axis - including the x-axis. Left-click to restore default zoom level.
    Regards Paul
  7. #17
    Jul 2003
    that is nice... how about adding to the table with just the + or - sign
  8. #18
    Jul 2003
    Yes sorry, there is some E39 OS's still outstanding (only a few), the new E39 .calz files added were for the E39A, essentially all 2013's, ATS, Malibu 2.0L Turbo etc.
    The E83 directory creation only happened in this update, in preparation , very observant Erik!
    It's gone because we got sick of replacing licenses for people who insisted on flashing the wrong OS in to E38's etc even after the warning. We are open to suggestions here, but at the moment we allow a full flash to proceed if the OS's are compatible (eg, not a 2010 in to a 2007) or if the OS is totally blank because we obviously have no way to check it against the .ctz file then.
    Simple:
    leave it in place for those that have the Stream?
  9. #19
    Apr 2010
    Hmmmmm I run efilive of my media pc and use my ipad as a keyboard. Buttons would personally be nicer. Anyone else want buttons???
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
  10. #20
    Jul 2007
    I think it's a little late to start making changes for the up coming release. RE: zooming, I like the scroll wheel and the key board short cuts but perhaps the addition of a "scroll bar" type zoom control would also be good. Click and drag it for a desired zoom level, which would also work with a touch screen device.
    Also, re: the BBL alarm times, I did some testing over the weekend and it seems I might be right. If the alarm duration is set for multiples of 10mS, the resulting duration seems about right.
    Simon
  1. 2013 EFILive Training Classes
    By zfuller123 in forum General (Diesel)
    Last Post: September 23rd, 2013, 05:22 AM
  2. EFILive RC 1 (March 01, 2013)
    Last Post: March 27th, 2013, 10:00 AM
  3. Replies: 0
    Last Post: January 7th, 2012, 04:01 PM
