Results 1 to 5 of 5
Thread: Idle Mode when Moving?
    Feb 2013
    Default Idle Mode when Moving?
    Currently, my tune is setup to use idle mode only when the vehicle is stopped and the throttle is closed, this seems standard. My question is, what if I were to increase the Max Speed for Idle Mode {B0107} from 0 mph to 256 mph? The idea would be that as long as the throttle is closed it will use idle mode, even when rolling. The reason for doing this would be prevent a high or bouncy idle when rolling in neutral, and the throttle cracker could be disabled. The idle trims would be able to hold the idle speed as if you were stationary.
    Some concerns I have is whether or not DFCO will work in idle mode. And I don't know how well idle mode would respond to deceleration when in gear, for example coasting off the highway in 4th gear at 2000 RPM.
    I don't have my heart set on this, just curious if it would work. All part of learning
    What about the rolling idle parameters. Mine are currently disabled as stock and I haven't found any stock tune files that use rolling idle.
    2001 Silverado 5.3L ECSB 2WD T56:
    T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
    EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
    Lifetime Member macca_779's Avatar
    Jan 2007
    Won't work as when you get off the throttle in gear it will pull air as it sees the high rpm error
    Feb 2013
    Quote Originally Posted by macca_779 View Post
    Thats what I thought. Thanks! I guess it would only work if I threw it in neutral every time I got off the gas.
    Jul 2003
    It works..... Do it.
    You just have to make the tables work out the right way. It works flawlessly and no need for throttle cracker.
    Feb 2013
    How do you have your tables setup? Will throttle follower still work?
  1. Hanging Idle When Moving
    By ferocity02 in forum Gen III V8 Specific
    Last Post: October 3rd, 2013, 03:14 AM
  2. Idle moving too rich with cooler air temps
    By Ritch in forum Gen III V8 Specific
    Last Post: October 7th, 2008, 08:36 AM
  3. moving to co3
    By stigmundfreud in forum Custom Operating Systems
    Last Post: October 3rd, 2007, 12:58 PM
  4. High idle when car moving
    By tazinhawaii in forum General (Petrol, Gas, Ethanol)
    Last Post: May 5th, 2006, 06:01 PM
  5. Idle in N whilst moving
    By daveb in forum General (Petrol, Gas, Ethanol)
    Last Post: September 2nd, 2005, 01:42 PM
