Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: having trouble with calc.ve
    Mar 2013
    Default having trouble with calc.ve
    i set up calc.ve and a quick first log, the numbers i am seeing in a few spots make no sense to me as far as a ve table goes. hopefully someone here can point me in the right direction. i also posted a screen shot of the LTFTBEN as that does not make sense to me either unless its supposed to be a multiplier
    Joe
ID:	14787Click image for larger version.
    Hey Joe,
    1st pic:
    - edit the map properties:
    - goto Cell tab, checkmark constrain cell size, and set the dell width;
    - goto Data tab, set Precision to 4, checkmark Show Units;
    - goto Row tab, checkmark Show Units;
    - goto Col tab, checkmark Show Units;
    - click Save,
    - Exit.
    2nd pic: the map is showing cell hit counts, see the n button is pressed... click on the x-bar button, this will show cell average value.
    Are you doing Calc.VET (newer) or Calc.VE (older)...?
    Mar 2013
    ok, ill modify the propertys now. thats the thing when i click X to average it out the map goes to 0. i am using calc.ve. but i do have the latest EFI software and flash scan v2. just bought everything last week.
    Mar 2013
    ok here is my ltftben map after following your instructions
    this is what happens to my calcve map when i hit the X
    Feb 2013
    What units are you using in the VE table? If you're using % then you have to input your engine displacement into the log file, otherwise it will come up with all 0's. Use g*K/kPa instead.
    The X button just removes cells with low cell count
    2001 Silverado 5.3L ECSB 2WD T56:
    T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
    EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
    Mar 2013
    i set it up for %. i just entered my displacement into the calc pids txt file. the log file still plays back as 0s but that is probably because there was no displacement entered at the time. ill try using g*k/kpa instead.
    i really appreciate the help.
    Mar 2013
    im not seeing a g*k/kpa pid
    Feb 2013
    Try using Calc.VET instead. I tried Calc.VE first but was then told that it was outdated, so I used Calc.VET and got good results.
    http://forum.efilive.com/showthread....in-single-log)
    http://forum.efilive.com/showthread....g-w-o-Wideband
    +1 use Calc.VET,
    see post #1 of that thread.
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. trouble with calc pids
    By Tool Guy in forum Tutorials
    Last Post: March 28th, 2013, 12:22 PM
  3. trouble accessing calc.vet map
    By Bill00Form in forum FlashScan V2
    Last Post: December 2nd, 2011, 05:37 AM
  4. idle trouble
    By goldenhp in forum Gen III V8 Specific
    Last Post: September 14th, 2011, 08:20 AM
