The MAF table looks right, the VE is not right. The MAF table you paste and multiply, the VE table you just paste in.
Post your calc pids text file.
2001 Silverado 5.3L ECSB 2WD T56:
T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
ok thats what i thought. heres the file. also dynamic air temp does not work for me.
You need to also log GM.DYNAIRTMP_DMA for CALC.DAT to work. Post up the log file.
it says dynamic air temp is not a supported pid for some reason
99 Hugger Orange Z28 - Crate LS6, Bolt-ons, TSP Long Tubes, Borla/QTP, Ram VDS Sintered Iron, Stage 2 T56, Mcleod Master, MWC 9", Strange Pro HD Aluminum, 4.30s, Spool, BMR Subframes - 11.30 @ 121.65
heres the log file
What OS are you using? The link says to use CALC.DYNAIRTMP if GM.DYNAIRTMP_DMA is not available. You will have to change it in the calc pids file too.
09360361 stock 99 camaro m6 OS.
ill have to go outside in a min and double check the dynamic air temp pid. right now without it connected to my car it only says that calc.selben is unsupported.
Hmm, the link doesn't say whether or not it should be available on yours. Maybe try CALC.DYNAIRTMP, I don't know where to get the calc pid for it though. Might not be bad to change OS to something newer like 12212156.
