i changed the operating system now the only thing not supported is Ben selected from LTFT or WB; SELBEN, (CALC.SELBEN)
99 Hugger Orange Z28 - Crate LS6, Bolt-ons, TSP Long Tubes, Borla/QTP, Ram VDS Sintered Iron, Stage 2 T56, Mcleod Master, MWC 9", Strange Pro HD Aluminum, 4.30s, Spool, BMR Subframes - 11.30 @ 121.65
You have to select these pids: SAE.LONGFT1/2, GM.EQIVRATIO, EXT.WO2LAM1, CALC.LTFTBEN, CALC.WO2BEN, CALC.SELBEN.
edit: correction
for LTFT Pids i have SAE.LONGFT1 & SAE.LONGFT2 (had these selected before) and there is GM.LONGFTAVG1 GM.LONGFTAVG2
GM.EQIVRATIO, CALC.LTFT & CALC.SELBEN were selected before as well.
i just added the others. is a wideband necessary for this? i was under the assumption i could use the factory o2s for PT
See this link I posted before: http://forum.efilive.com/showthread....g-w-o-Wideband
joecar helped me set it up to do it w/o a wideband. I honestly haven't figured out how it works yet, but it seemed to work well enough for me.
2001 Silverado 5.3L ECSB 2WD T56:
T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
