Thread: Twin Turbo Tuning
    Mar 2009
    Default Twin Turbo Tuning
    Just trying to slowly learn more and more about tuning.
    As for tuning for twin turbo's I would assume to increase boost pressure faster then then on a single? I would also believe I would need to lower PW to achieve same power output due to increased air going into the engine?
    Thanks for the help gentlemen.
    2002 Chevy Duramax with a few supporting mods.
    Mar 2009
    No one?
    May 2008
    Diesel guys must be on spring break.
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Mar 2009
    Quote Originally Posted by nevinsb View Post
    I guess so.
    Junior Member xploitdiesel's Avatar
    Jun 2012
    Never hear anything on this? When you say twin tuning are you running two fixed vane turbo? If so, there's not much you can do to control the boost as it depends on the duration and timing...one thing I do is disable the underboost and overboost codes..I think around P0234 is where they are...and disable anything pertaining to variable vane turbo...that's just what I have done and had good luck with.
    Nov 2009
    Quote Originally Posted by xploitdiesel View Post
    I suggest not disabling under boost codes. The reason they code are legit. ....match up desired vs actual and you will not get a under boost code. The under boost can also put the Ecu into a limp home mode in which with the code off would be hard to diagnose.
    -Kory
    http://www.PPEI.com/
  1. Twin Turbo CTS-V help
    By gotabav in forum Gen III V8 Specific
    Last Post: July 24th, 2011, 10:29 PM
  2. Twin Turbo Tuning probelms
    By Picto in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 23rd, 2011, 04:12 AM
  3. twin turbo's
    By limited cv8r in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 15th, 2007, 03:22 AM
  4. STS Twin Turbo
    By purrvert in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 20th, 2006, 09:25 AM
  5. 02 Vette Twin Turbo
    By lplott in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 25th, 2006, 04:17 AM
