Results 1 to 3 of 3
Thread: RPM remains high after accel
    Default RPM remains high after accel
    I might be missing something or just being dense. When the clutch is depressed after hard accel the RPM's remain at about 3000 for about 10-15 secs. I have checked all the decay modifiers that i can think of and only made a small change in the rpm level. This is a 02 camaro with crazy cam and dart heads. This was my first N/A tune dealing with a cam. definately a different animal! It did however come welll I thought. Idle and start up is almost like stock great part throttle and drivebility. anyhow, any thoughts would be appreciated.
    Thanks,
    madprof01
    Oct 2004
    Try logging the airflow values for the Throttle Cracker and Throttle Follower (if you have not already). This will show you the amount of airflow added and the speed at witch is being decayed.
    That is my first suggestion.
    Andrew
    EFILive Crew
    Well just for the record, KISS has once again layed one on me! Overcomplicating or thinking set up a poor result untill rest and detachment had been achieved! The higher numbers on the top right of the timing table were 7 sometimes 4 deg. with the big cam and heads and GMs strategy some of the idle had moved up in the table. These low numbers do not work with this combination. gotta love those friendly reminders!
    madprof01
    P.S. Keep
    It
    Simple
    Stupid
  1. Cant get high fan with a/c
    By lowws6 in forum Gen III V8 Specific
    Last Post: August 31st, 2010, 06:03 PM
  2. Will changing the VE map alter accel pump/transient fueling?
    By Supercharged111 in forum Vortec V6/V8 Specific
    Last Post: June 18th, 2009, 08:10 PM
  3. Accel enrichment
    By Camaro SS in forum Custom Operating Systems
    Last Post: February 9th, 2009, 08:12 AM
  4. B5208 Rev limiter accel modifier
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: September 22nd, 2008, 07:47 AM
  5. Need help tuning gmpp intake w/ accel 1150cfm tb
    By wadesns in forum Gen III V8 Specific
    Last Post: July 13th, 2007, 04:25 AM
