Results 1 to 4 of 4
Thread: Went from hot weather to extreme cold not truck runs like crap
    Jan 2012
    Default Went from hot weather to extreme cold not truck runs like crap
    I recently moved from Tucson AZ where it was in the 80s to minot ND where it has gotten down to -10*f. It was running very rich so I did some logging and updated the ve table. Every time I go from park to gear the rpms drop very low and sometimes dies. What else do I need to change? I've tried to do the rafig but I'm at a loss on that one
    2011 Cadillac Escalade ESV. BTR 218/224 .553/.553 110LSA. Built 6L80 with 278mm Circle D 2800 stall converter.
    Feb 2012
    Andy,
    If it was dialled in well before, and is out everywhere, you could try putting the VE tabl eback the way it was and using the IAT VE Multiplier {A0014}.
    Chances are, this table up it's still set to 1.000 at the IATs you're currently seeing.
    Jan 2012
    Yes. The ve was pretty much perfect before the move. But the atmosphere was around 89kpa there so that's how I had my tune set up. It's 96kpa here so it was actually commanding 13.5 afr at cruise. And I also had to adjust the timing as it was only commanding 20* at cruise. Only issue now is where it sometimes stalls when I put it into gear.
    Jan 2012
    Okay, in the mornings before I leave for work I will use the remote start to warm up the truck. By the time I get in to leave the coolant is around 160-170*F. And afr will be around 16.5-17. When I put it in gear afr will go to 15.5 which is what I'm commanding. Would this be to much in the desired airflow table?
  1. EGR Deleted 6.7L Runs very rough when cold
    By Mitco39 in forum Cummins 6.7L
    Last Post: March 29th, 2012, 05:27 PM
  2. Cold Weather Tune
    By 2500ak in forum Gen III V8 Specific
    Last Post: February 2nd, 2010, 05:55 AM
  3. Cold weather=Rich tune???
    By coryhussey in forum Gen III V8 Specific
    Last Post: January 17th, 2009, 11:36 AM
  4. auto ve and extreme cold
    By tokymon in forum Vortec V6/V8 Specific
    Last Post: December 31st, 2008, 10:38 AM
  5. Transplant + New Cam & heads, runs like crap-HELP
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: May 23rd, 2008, 05:44 AM
