Thread: PID sample rate
    Senior Member Behold's Avatar
    Apr 2010
    Default PID sample rate
    Can the PID sample rate be increased on BBX logging????
    Thanks Antony
    Holden Commodore GTS - LS1 5.7
    12 rib Crank Driven Vortech V2 Centri Charger (Intercooled) 9 PSI.
    LS6 Intake
    LS6 Heads
    YT 1.7 Roller Rockers
    BTR Dual Spring with Ti retainers
    BTR Hardend 7.400 Push rods
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    PCM LS1B with 512KB Running COS5 v01290005
    Selecting fewer PIDs will mean faster logging speeds. Select only a few channels (6 or7) so that only the first packet in the "PID Usage" display contains channel data.
    Regards Paul
    Apr 2010
    I'm not quite following. I'm in the v8 tool. I have only 5 pids and there is no option to have high priority on the pid or change the rate at all.
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    Each additional packet that is used to log PID channel data slows down the scan rate. So if you only select enough PIDs that their channel data fits into one packet, then you'll have the fastest logging speed.
    FWIW, I really like how V8 makes it a lot more visual to see the # of channels a particular PID requires. Bring on pass through logging! Seriously though, after using V8 even with the chart view it's tough to go back to V7.5. Especially with how long it takes to plot in V7.5 vs almost instant in V8.
    +1 good comment.
  1. 02 LB7 balance rate PID's gone from list?
    By haulinit in forum Duramax LB7
    Last Post: June 11th, 2012, 12:37 PM
  2. Map Sample rate {B2105}
    By Mark300 in forum E37, E38 & E67 PFI ECM's
    Last Post: January 2nd, 2010, 07:00 PM
  3. Sample Rate
    By DMaxME in forum General
    Last Post: October 14th, 2009, 08:59 AM
  4. newbee looking for some sample tunes
    By 03FullPull in forum Gen III V8 Specific
    Last Post: July 31st, 2008, 01:31 PM
  5. sample rate V2
    By Lennart in forum Diesel
    Last Post: November 30th, 2006, 12:28 PM
