Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: Just finished my COS tune and no start
    Jan 2012
    Default Just finished my COS tune and no start
    I just uploaded a COS3 tune and went through the tutorial and made all the changes it suggested. I also changed my data to match that of my injectors, but the truck won't start. It fires right away then just cranks. Shut the key off then try again and the same thing.
    I attached my tune and any help is appreciated. Riebel 2003 5_0001.tun
    what size injectors are you using
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    i see B4001 looks wrong.you have it at
    LABELS Injector Flow Rate (Grams/Second)
    Manifold Vacuum kPa {link: GM.MANVAC} Value
    0 71.656250
    5 71.656250
    10 71.656250
    15 71.656250
    20 71.656250
    25 71.656250
    30 71.656250
    35 71.656250
    40 71.656250
    45 71.656250
    50 71.656250
    55 71.656250
    60 71.656250
    65 71.656250
    70 71.656250
    75 71.656250
    80 71.656250
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Jan 2012
    That's what I calculated for the injectors. Are you saying the units may be wrong?
    Jan 2012
    Do I need to do any relearns after the full flash? I did have to recover my PCM. Would that have anything to do with it?
    Lifetime Member limited cv8r's Avatar
    May 2005
    It looks as though you may have entered the data as LB/HR instead of G/sec in B4001, so 71.6563 LB/HR = 9.02853 G/SEC. Good pickup gmperformancecentre.
    Quote Originally Posted by limited cv8r View Post
    As limited cv8r said.you have enter the data wrong,should be 9.02853 not 71.6563.
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Jan 2012
    Thanks guys! Ill give that a try.
    +1 check your B4001 units.
    Good catch Steve.
    BTW: A0001,2,12,13 are out-of-range.
  1. Need a COS to start with
    By pullincrazy88 in forum Custom Operating Systems
    Last Post: June 12th, 2011, 10:39 AM
  2. COS and no start
    By turbogtu in forum General
    Last Post: September 15th, 2009, 02:27 PM
  3. car wont start with COS#5
    By articSS in forum Custom Operating Systems
    Last Post: September 19th, 2007, 12:43 PM
  4. Almost finished AutoVE
    By Spdfrk1990 in forum Gen III V8 Specific
    Last Post: July 6th, 2007, 02:27 PM
  5. Finished 3 bar SD TUNE. How do I return to closed loop?
    Last Post: October 13th, 2005, 04:56 PM
