Results 1 to 4 of 4
Thread: Flashscan generated ECM lock issue....
    Junior Member LPDTuning's Avatar
    Feb 2008
    Default Flashscan generated ECM lock issue....
    Hey folks, I got a customers 04 LB7 which I tuned around a month ago. When I installed the DSP5 I used a Flashscan generated ECM lock to lock the controller. He came over today to get it retuned and I cannot unlock the ECM. I tried several times and even used ALT keys. I went into the PCM locks page in the program files to find the seed and the key but I'm not sure which one it is. How do I find the ECM serial number so I can find the seed and key I need?
    Another thing, The customer went to start the truck yesterday and It suddenly had a no crank issue out of the blue. He called me and I told him to unhook the batteries for a while and see if it would start and it did. So, did something in the ECM take a crap? Just kind of weird how he has a no start issue one day and now I cant unlock the ECM. Thanks for any advice guys.
    -Danny-
    "Napalm"........'03 LB7 Ext Cab 2wd, Spiral Grey Metallic, lowered, Fuel Rampage wrapped in Nitto 420S, Stainless Diesel S475 5-Blade over stock.
    Feb 2008
    Really??? No body can tell me??
    -Danny-
    Dec 2005
    Paul can get you the seed/key if you can get him the ecm serial number and look in the PCM locks ini file.
    If it is a 2003 or 2004 and it has any aftermarket electronics pull all the fuses.
    www.mscservices.net
    Feb 2008
    Here is the first serial number/ seed and key info on the ini. page that was at the top. I dont know if they are in order from top to bottom or bottom to top but I have both the bottom and the top set of numbers.
    Top is: [3280CT09AX71]
    Seed=$788C
    Key=$EC8FFF09
    Bottom is:[3170CT08GZT1]
    Seed=$3AAB
    Key=$8DD52A81
    -Danny-
  1. Generated vs actual A/F discrepancy
    By mysunnshine in forum General
    Last Post: September 7th, 2014, 10:10 AM
  2. Replies: 10
    Last Post: July 7th, 2012, 07:52 AM
  3. LC-1 flashscan issue
    By stroker97k1500 in forum Gen III V8 Specific
    Last Post: June 7th, 2008, 05:59 PM
  4. ECM Lock and unlock
    By markgammel in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2007, 02:59 AM
