Results 1 to 9 of 9
Thread: clearing codes with V2 not using a laptop??
    Jan 2013
    Default clearing codes with V2 not using a laptop??
    is it possible to just plug in my V2 to the obd2 port and clear/read codes without the use of a laptop?? i know i can pull codes with it but they dont have any description and every time i try to clear a code it will say they are cleared when they really are still there? simply put it doesnt really clear codes... the only way ive been able to clear codes is when connected to my laptop.
    Yes, go into the Diagnostics screen, then click Trouble Codes, then Clear DTCs. I cant remember the exact verbage, but that's pretty close.
    Jan 2013
    thats what i tried doing but when i "clear" them theyre still there!
    Jul 2007
    Are they being set again? What are the codes and what's been done to the car?
    Jan 2013
    Quote Originally Posted by swingtan View Post
    they arent being set again because if i clear them ith my laptop hooked up they go away until i do a drive cycle. its on my 2008 Ram 6.7 Cummins and all ive done is deleted emissions equipment so far
    Jul 2007
    Sounds like a script / config file issue in the BBL settings. If you haven't updated your firmware to the latest release (Jun 2012) and also updated the entire config filesystem in the V2, then I'd do that first. If the problem still remains, it may be a bug.
    Check their status... i.e. the History flag might be on and the Current flag might be off...
    post a picture.
    Jan 2013
    i think i already did this when i first bought it back in early february. i have the build 211 and build 203 software loaded and running on my laptop. is there anything i have to do to the actual V2 handheld itself?
    Jan 2013
    post a picture.
    how do i go about doing this? im a noob!
  1. Clearing history codes
    By Denaliano in forum General
    Last Post: April 13th, 2014, 05:50 AM
  2. Help Clearing codes EFI Live V1
    By speedygoss in forum Duramax LLY
    Last Post: January 31st, 2010, 01:14 PM
  3. Clearing History
    By Lextech in forum Tips and tricks
    Last Post: June 29th, 2009, 04:50 PM
  4. Clearing Allison codes?
    By duramaximizer in forum FlashScan V2
    Last Post: May 18th, 2008, 05:33 PM
