Results 1 to 10 of 17
Thread: GMH V6 communication problem
    Apr 2013
    Default GMH V6 communication problem
    I have got a VX commodore engine in a different vehicle that I am trying to talk to with EFILive V4 with an ebay USB ALDL cable.
    I am hoping my issue is just timing settings, but I don't have enough knowledge to work out the right settings.
    Chatter capture is a repetition of this....
    The first line is my current heartbeat.
    I have 3 GMH VX V6 files, one is UPDATED, the other is FIXED. none work, each show similar issues.
    Can someone who knows more than me share their wisdom?
    Thanks!
    Code:
    44:49.429: (44:49.429)$08,$55,$A3
    44:49.545: Com timeout: Expecting frame header byte
    44:49.551: No chatter found
    44:49.573: (44:49.573)$40,$58,$51,$12,$43,$C2
    44:49.595: (44:49.595)$41,$63,$00,$00,$00,$68,$41,$00,$00,$00,$D8,$C5,$00,$00,$00,$6D,$A9
    44:49.609: (44:49.609)$A8,$55,$03
    44:49.624: (44:49.624)$20,$55,$8B
    44:49.639: (44:49.639)$D8,$55,$D3
    44:49.655: (44:49.654)$90,$55,$1B
    44:49.669: (44:49.669)$A0,$55,$0B
    44:49.693: (44:49.693)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    44:49.708: (44:49.708)$40,$58,$51,$12,$43,$C2
    44:49.730: (44:49.730)$41,$63,$00,$00,$00,$68,$41,$00,$00,$00,$D8,$C5,$00,$00,$00,$83,$93
    44:49.744: (44:49.744)$08,$55,$A3
    44:49.857: Com timeout: Expecting frame header byte
    44:49.864: No chatter found
    44:49.888: (44:49.888)$40,$58,$51,$12,$43,$C2
    44:49.910: (44:49.910)$41,$63,$00,$00,$00,$68,$41,$00,$00,$00,$D8,$C5,$00,$00,$00,$9F,$77
    44:49.924: (44:49.924)$A8,$55,$03
    44:49.939: (44:49.939)$20,$55,$8B
    44:49.954: (44:49.954)$D8,$55,$D3
    44:49.969: (44:49.969)$90,$55,$1B
    44:49.984: (44:49.984)$A0,$55,$0B
    44:50.008: (44:50.008)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    44:50.023: (44:50.023)$40,$58,$51,$12,$43,$C2
    44:50.045: (44:50.045)$41,$63,$00,$00,$00,$68,$41,$00,$00,$00,$D8,$C5,$00,$00,$00,$15,$01
    44:50.059: (44:50.059)$08,$55,$A3
    44:50.170: Com timeout: Expecting frame header byte
    44:50.176: No chatter found
    44:50.203: (44:50.203)$40,$58,$51,$12,$43,$C2
    44:50.225: (44:50.225)$41,$63,$00,$00,$00,$68,$41,$00,$00,$00,$D8,$C5,$00,$00,$00,$32,$E4
    44:50.239: (44:50.239)$A8,$55,$03
    44:50.254: (44:50.254)$20,$55,$8B
    44:50.269: (44:50.269)$D8,$55,$D3
    44:50.284: (44:50.284)$90,$55,$1B
    44:50.299: (44:50.299)$A0,$55,$0B
    44:50.324: (44:50.324)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    44:50.338: (44:50.338)$40,$58,$51,$12,$43,$C2
    44:50.360: (44:50.360)$41,$63,$00,$00,$00,$68,$41,$00,$00,$00,$D8,$C5,$00,$00,$00,$47,$CF
    44:50.374: (44:50.374)$08,$55,$A3
    44:50.482: Com timeout: Expecting frame header byte
    44:50.489: No chatter found
    44:50.518: (44:50.518)$40,$58,$51,$12,$43,$C2
    44:50.540: (44:50.540)$41,$63,$00,$00,$00,$68,$41,$00,$00,$00,$D8,$C5,$00,$00,$00,$64,$B2
    44:50.554: (44:50.554)$A8,$55,$03
    44:50.569: (44:50.569)$20,$55,$8B
    44:50.584: (44:50.584)$D8,$55,$D3
    44:50.599: (44:50.599)$90,$55,$1B
    44:50.614: (44:50.614)$A0,$55,$0B
    44:50.638: (44:50.638)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    44:50.653: (44:50.653)$40,$58,$51,$12,$43,$C2
    44:50.675: (44:50.675)$41,$63,$00,$00,$00,$68,$41,$00,$00,$00,$D8,$C5,$00,$00,$00,$7A,$9C
    44:50.689: (44:50.689)$08,$55,$A3
    44:50.795: Com timeout: Expecting frame header byte
    44:50.801: No chatter found
    44:50.833: (44:50.833)$40,$58,$51,$12,$43,$C2
    44:50.855: (44:50.855)$41,$63,$00,$00,$00,$68,$41,$00,$00,$00,$D8,$C5,$00,$00,$00,$97,$7F
    44:50.869: (44:50.869)$A8,$55,$03
    44:50.884: (44:50.884)$20,$55,$8B
    44:50.899: (44:50.899)$D8,$55,$D3
    44:50.914: (44:50.914)$90,$55,$1B
    44:50.929: (44:50.929)$A0,$55,$0B
    44:50.954: (44:50.954)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    44:50.968: (44:50.968)$40,$58,$51,$12,$43,$C2
    44:50.991: (44:50.991)$41,$63,$00,$00,$00,$68,$41,$00,$00,$00,$D8,$C5,$00,$00,$00,$0C,$0A
    44:51.004: (44:51.004)$08,$55,$A3
    Apr 2013
    Very shortly after posting and looking at timing I changed my T2 to 200ms and I did get it to connect and work!!!
    However while running, if I hit the green button on EFILive, it doesn't always connect. Shows....
    Code:
    58:52.162: Start macro: Engine data: DATA
    58:52.171: Synchronising ALDL communications...
    58:52.171: Waiting for heartbeat: $08,$55,$A3
    58:52.171: Waiting for Aldl bus silence of at least 12ms...
    58:52.386: Com timeout: Expecting frame header byte
    58:52.414: Synchronising ALDL communications...
    58:52.414: Waiting for heartbeat: $08,$55,$A3
    58:52.414: Waiting for Aldl bus silence of at least 12ms...
    58:52.620: Com timeout: Expecting frame header byte
    58:52.648: Synchronising ALDL communications...
    58:52.648: Waiting for heartbeat: $08,$55,$A3
    58:52.648: Waiting for Aldl bus silence of at least 12ms...
    58:52.855: Com timeout: Expecting frame header byte
    58:52.888: Stop macro: Engine data: DATA
    Apr 2013
    As a further follow up, to connect it seems I have to hit the green button in EFILive shortly after switching the ignition on.
    If I leave the ignition on (engine running or not) for 20 seconds or so, it will not connect. Just shows what I pasted in my last post. Why would this be?
    On a side note the program seems like it does what I want it to do so I will be buying the pro version.
    When you see the "Comm timeout: Expecting frame header byte", that just means the software waited for "x" milliseconds but no data was sent by the vehicle prior to "x" milliseconds elapsing.
    "x" milliseconds is defined by T3 (when T1 and T2 are set to 0)
    In your first post, I presume T3 was set to 100ms and the time between these two frames is larger than 100ms:
    When you changed T3 to 200ms, that stopped the timeout occurring because all frames are arriving within 200ms of the previous frame.
    To figure out what is happening when you switch on the ignition can you please do the following:
    Set the View->Serial I/O option.
    With ignition off, select Aldl->Listen to chatter
    Stop after about 10 seconds.
    Copy/Paste the output so I can see it in this thread.
    Select Aldl->Listen to chatter
    Switch ignition on (while listening to chatter).
    Wait 20 seconds
    Apr 2013
    Paul,
    Thanks a lot for the help.
    Ignition off:
    Code:
    34:48.033: Scan for chatter...
    34:48.033: Waiting for Aldl bus silence of at least 12ms...
    34:48.042: Start reading frame
    34:48.245: Com timeout: Expecting frame header byte
    34:48.264: No chatter found
    34:48.270: Start reading frame
    34:48.464: Com timeout: Expecting frame header byte
    34:48.472: No chatter found
    Apr 2013
    Ignition switched on while listening:
    Code:
    37:06.144: Start reading frame
    37:06.155: Aldl frame header byte: $11
    37:06.155: Aldl frame length byte: $5C
    37:06.155: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:06.155: Finished reading frame
    37:06.155: (37:06.155)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:06.192: Start reading frame
    37:06.192: Aldl frame header byte: $40
    37:06.192: Aldl frame length byte: $58
    37:06.192: Recv: $40,$58,$FF,$FF,$FF,$6B
    37:06.192: Finished reading frame
    37:06.192: (37:06.192)$40,$58,$FF,$FF,$FF,$6B
    37:06.229: Start reading frame
    37:06.229: Aldl frame header byte: $ 8
    37:06.229: Aldl frame length byte: $55
    37:06.229: Recv: $08,$55,$A3
    37:06.229: Finished reading frame
    37:06.229: (37:06.229)$08,$55,$A3
    37:06.266: Start reading frame
    37:06.349: Aldl frame header byte: $40
    37:06.349: Aldl frame length byte: $58
    37:06.349: Recv: $40,$58,$FF,$FF,$FF,$6B
    37:06.349: Finished reading frame
    37:06.349: (37:06.349)$40,$58,$FF,$FF,$FF,$6B
    37:06.373: Start reading frame
    37:06.373: Aldl frame header byte: $41
    37:06.373: Aldl frame length byte: $63
    37:06.373: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$58,$C5,$00,$00,$00,$2C,$9A
    37:06.373: Finished reading frame
    37:06.373: (37:06.373)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$58,$C5,$00,$00,$00,$2C,$9A
    37:06.398: Start reading frame
    37:06.398: Aldl frame header byte: $A8
    37:06.398: Aldl frame length byte: $55
    37:06.398: Recv: $A8,$55,$03
    37:06.398: Finished reading frame
    37:06.398: (37:06.398)$A8,$55,$03
    37:06.422: Start reading frame
    37:06.422: Aldl frame header byte: $20
    37:06.422: Aldl frame length byte: $55
    37:06.422: Recv: $20,$55,$8B
    37:06.422: Finished reading frame
    37:06.422: (37:06.422)$20,$55,$8B
    37:06.446: Start reading frame
    37:06.446: Aldl frame header byte: $D8
    37:06.446: Aldl frame length byte: $55
    37:06.446: Recv: $D8,$55,$D3
    37:06.446: Finished reading frame
    37:06.446: (37:06.446)$D8,$55,$D3
    37:06.470: Start reading frame
    37:06.470: Aldl frame header byte: $90
    37:06.470: Aldl frame length byte: $55
    37:06.470: Recv: $90,$55,$1B
    37:06.470: Finished reading frame
    37:06.470: (37:06.470)$90,$55,$1B
    37:06.494: Start reading frame
    37:06.494: Aldl frame header byte: $A0
    37:06.494: Aldl frame length byte: $55
    37:06.494: Recv: $A0,$55,$0B
    37:06.494: Finished reading frame
    37:06.494: (37:06.494)$A0,$55,$0B
    37:06.518: Start reading frame
    37:06.518: Aldl frame header byte: $11
    37:06.518: Aldl frame length byte: $5C
    37:06.518: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:06.518: Finished reading frame
    37:06.518: (37:06.518)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:06.542: Start reading frame
    37:06.542: Aldl frame header byte: $40
    37:06.542: Aldl frame length byte: $58
    37:06.542: Recv: $40,$58,$51,$12,$43,$C2
    37:06.542: Finished reading frame
    37:06.542: (37:06.542)$40,$58,$51,$12,$43,$C2
    37:06.567: Start reading frame
    37:06.567: Aldl frame header byte: $41
    37:06.567: Aldl frame length byte: $63
    37:06.567: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$41,$05
    37:06.567: Finished reading frame
    37:06.567: (37:06.567)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$41,$05
    37:06.591: Start reading frame
    37:06.591: Aldl frame header byte: $ 8
    37:06.591: Aldl frame length byte: $55
    37:06.591: Recv: $08,$55,$A3
    37:06.591: Finished reading frame
    37:06.591: (37:06.591)$08,$55,$A3
    37:06.615: Start reading frame
    37:06.664: Aldl frame header byte: $40
    37:06.664: Aldl frame length byte: $58
    37:06.664: Recv: $40,$58,$51,$12,$43,$C2
    37:06.664: Finished reading frame
    37:06.664: (37:06.664)$40,$58,$51,$12,$43,$C2
    37:06.689: Start reading frame
    37:06.689: Aldl frame header byte: $41
    37:06.689: Aldl frame length byte: $63
    37:06.689: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$5E,$E8
    37:06.689: Finished reading frame
    37:06.689: (37:06.689)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$5E,$E8
    37:06.713: Start reading frame
    37:06.713: Aldl frame header byte: $A8
    37:06.713: Aldl frame length byte: $55
    37:06.713: Recv: $A8,$55,$03
    37:06.713: Finished reading frame
    37:06.713: (37:06.713)$A8,$55,$03
    37:06.737: Start reading frame
    37:06.737: Aldl frame header byte: $20
    37:06.737: Aldl frame length byte: $55
    37:06.738: Recv: $20,$55,$8B
    37:06.738: Finished reading frame
    37:06.738: (37:06.737)$20,$55,$8B
    37:06.762: Start reading frame
    37:06.762: Aldl frame header byte: $D8
    37:06.762: Aldl frame length byte: $55
    37:06.762: Recv: $D8,$55,$D3
    37:06.762: Finished reading frame
    37:06.762: (37:06.762)$D8,$55,$D3
    37:06.786: Start reading frame
    37:06.786: Aldl frame header byte: $90
    37:06.786: Aldl frame length byte: $55
    37:06.786: Recv: $90,$55,$1B
    37:06.786: Finished reading frame
    37:06.786: (37:06.786)$90,$55,$1B
    37:06.810: Start reading frame
    37:06.810: Aldl frame header byte: $A0
    37:06.810: Aldl frame length byte: $55
    37:06.810: Recv: $A0,$55,$0B
    37:06.810: Finished reading frame
    37:06.810: (37:06.810)$A0,$55,$0B
    37:06.834: Start reading frame
    37:06.834: Aldl frame header byte: $11
    37:06.834: Aldl frame length byte: $5C
    37:06.834: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:06.834: Finished reading frame
    37:06.834: (37:06.834)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:06.858: Start reading frame
    37:06.858: Aldl frame header byte: $40
    37:06.858: Aldl frame length byte: $58
    37:06.858: Recv: $40,$58,$51,$12,$43,$C2
    37:06.858: Finished reading frame
    37:06.858: (37:06.858)$40,$58,$51,$12,$43,$C2
    37:06.881: Start reading frame
    37:06.881: Aldl frame header byte: $41
    37:06.881: Aldl frame length byte: $63
    37:06.881: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$74,$D2
    37:06.881: Finished reading frame
    37:06.881: (37:06.881)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$74,$D2
    37:06.905: Start reading frame
    37:06.905: Aldl frame header byte: $ 8
    37:06.905: Aldl frame length byte: $55
    37:06.905: Recv: $08,$55,$A3
    37:06.905: Finished reading frame
    37:06.905: (37:06.905)$08,$55,$A3
    37:06.930: Start reading frame
    37:06.979: Aldl frame header byte: $40
    37:06.979: Aldl frame length byte: $58
    37:06.979: Recv: $40,$58,$51,$12,$43,$C2
    37:06.979: Finished reading frame
    37:06.979: (37:06.979)$40,$58,$51,$12,$43,$C2
    37:07.004: Start reading frame
    37:07.004: Aldl frame header byte: $41
    37:07.004: Aldl frame length byte: $63
    37:07.004: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$91,$B5
    37:07.004: Finished reading frame
    37:07.004: (37:07.004)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$91,$B5
    37:07.028: Start reading frame
    37:07.028: Aldl frame header byte: $A8
    37:07.028: Aldl frame length byte: $55
    37:07.028: Recv: $A8,$55,$03
    37:07.028: Finished reading frame
    37:07.028: (37:07.028)$A8,$55,$03
    37:07.065: Start reading frame
    37:07.065: Aldl frame header byte: $20
    37:07.065: Aldl frame length byte: $55
    37:07.065: Recv: $20,$55,$8B
    37:07.065: Finished reading frame
    37:07.065: (37:07.065)$20,$55,$8B
    37:07.089: Start reading frame
    37:07.089: Aldl frame header byte: $D8
    37:07.089: Aldl frame length byte: $55
    37:07.089: Recv: $D8,$55,$D3
    37:07.089: Finished reading frame
    37:07.089: (37:07.089)$D8,$55,$D3
    37:07.113: Start reading frame
    37:07.113: Aldl frame header byte: $90
    37:07.113: Aldl frame length byte: $55
    37:07.113: Recv: $90,$55,$1B
    37:07.113: Finished reading frame
    37:07.113: (37:07.113)$90,$55,$1B
    37:07.137: Start reading frame
    37:07.137: Aldl frame header byte: $A0
    37:07.137: Aldl frame length byte: $55
    37:07.137: Recv: $A0,$55,$0B
    37:07.137: Finished reading frame
    37:07.137: (37:07.137)$A0,$55,$0B
    37:07.162: Start reading frame
    37:07.162: Aldl frame header byte: $11
    37:07.162: Aldl frame length byte: $5C
    37:07.162: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:07.162: Finished reading frame
    37:07.162: (37:07.162)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:07.186: Start reading frame
    37:07.186: Aldl frame header byte: $40
    37:07.186: Aldl frame length byte: $58
    37:07.186: Recv: $40,$58,$51,$12,$43,$C2
    37:07.186: Finished reading frame
    37:07.186: (37:07.186)$40,$58,$51,$12,$43,$C2
    37:07.209: Start reading frame
    37:07.209: Aldl frame header byte: $41
    37:07.209: Aldl frame length byte: $63
    37:07.209: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$06,$40
    37:07.209: Finished reading frame
    37:07.209: (37:07.209)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$06,$40
    37:07.233: Start reading frame
    37:07.233: Aldl frame header byte: $ 8
    37:07.233: Aldl frame length byte: $55
    37:07.233: Recv: $08,$55,$A3
    37:07.233: Finished reading frame
    37:07.233: (37:07.233)$08,$55,$A3
    37:07.257: Start reading frame
    37:07.295: Aldl frame header byte: $40
    37:07.295: Aldl frame length byte: $58
    37:07.295: Recv: $40,$58,$51,$12,$43,$C2
    37:07.295: Finished reading frame
    37:07.295: (37:07.295)$40,$58,$51,$12,$43,$C2
    37:07.319: Start reading frame
    37:07.319: Aldl frame header byte: $41
    37:07.319: Aldl frame length byte: $63
    37:07.319: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$23,$23
    37:07.319: Finished reading frame
    37:07.319: (37:07.319)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$23,$23
    37:07.345: Start reading frame
    37:07.345: Aldl frame header byte: $A8
    37:07.345: Aldl frame length byte: $55
    37:07.345: Recv: $A8,$55,$03
    37:07.345: Finished reading frame
    37:07.345: (37:07.345)$A8,$55,$03
    37:07.368: Start reading frame
    37:07.368: Aldl frame header byte: $20
    37:07.368: Aldl frame length byte: $55
    37:07.368: Recv: $20,$55,$8B
    37:07.368: Finished reading frame
    37:07.368: (37:07.368)$20,$55,$8B
    37:07.390: Start reading frame
    37:07.390: Aldl frame header byte: $D8
    37:07.390: Aldl frame length byte: $55
    37:07.390: Recv: $D8,$55,$D3
    37:07.390: Finished reading frame
    37:07.390: (37:07.390)$D8,$55,$D3
    37:07.413: Start reading frame
    37:07.413: Aldl frame header byte: $90
    37:07.413: Aldl frame length byte: $55
    37:07.413: Recv: $90,$55,$1B
    37:07.413: Finished reading frame
    37:07.413: (37:07.413)$90,$55,$1B
    37:07.435: Start reading frame
    37:07.435: Aldl frame header byte: $A0
    37:07.435: Aldl frame length byte: $55
    37:07.435: Recv: $A0,$55,$0B
    37:07.435: Finished reading frame
    37:07.435: (37:07.435)$A0,$55,$0B
    37:07.458: Start reading frame
    37:07.458: Aldl frame header byte: $11
    37:07.458: Aldl frame length byte: $5C
    37:07.458: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:07.458: Finished reading frame
    37:07.458: (37:07.458)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:07.480: Start reading frame
    37:07.480: Aldl frame header byte: $40
    37:07.480: Aldl frame length byte: $58
    37:07.480: Recv: $40,$58,$51,$12,$43,$C2
    37:07.480: Finished reading frame
    37:07.480: (37:07.480)$40,$58,$51,$12,$43,$C2
    37:07.502: Start reading frame
    37:07.502: Aldl frame header byte: $41
    37:07.502: Aldl frame length byte: $63
    37:07.502: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$39,$0D
    37:07.502: Finished reading frame
    37:07.502: (37:07.502)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$39,$0D
    37:07.524: Start reading frame
    37:07.524: Aldl frame header byte: $ 8
    37:07.525: Aldl frame length byte: $55
    37:07.525: Recv: $08,$55,$A3
    37:07.525: Finished reading frame
    37:07.525: (37:07.524)$08,$55,$A3
    37:07.547: Start reading frame
    37:07.610: Aldl frame header byte: $40
    37:07.610: Aldl frame length byte: $58
    37:07.610: Recv: $40,$58,$51,$12,$43,$C2
    37:07.610: Finished reading frame
    37:07.610: (37:07.610)$40,$58,$51,$12,$43,$C2
    37:07.633: Start reading frame
    37:07.633: Aldl frame header byte: $41
    37:07.633: Aldl frame length byte: $63
    37:07.633: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$55,$F1
    37:07.633: Finished reading frame
    37:07.633: (37:07.633)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$55,$F1
    37:07.656: Start reading frame
    37:07.656: Aldl frame header byte: $A8
    37:07.656: Aldl frame length byte: $55
    37:07.656: Recv: $A8,$55,$03
    37:07.656: Finished reading frame
    37:07.656: (37:07.656)$A8,$55,$03
    37:07.679: Start reading frame
    37:07.679: Aldl frame header byte: $20
    37:07.680: Aldl frame length byte: $55
    37:07.680: Recv: $20,$55,$8B
    37:07.680: Finished reading frame
    37:07.680: (37:07.679)$20,$55,$8B
    37:07.702: Start reading frame
    37:07.702: Aldl frame header byte: $D8
    37:07.702: Aldl frame length byte: $55
    37:07.702: Recv: $D8,$55,$D3
    37:07.702: Finished reading frame
    37:07.702: (37:07.702)$D8,$55,$D3
    37:07.725: Start reading frame
    37:07.725: Aldl frame header byte: $90
    37:07.725: Aldl frame length byte: $55
    37:07.725: Recv: $90,$55,$1B
    37:07.725: Finished reading frame
    37:07.725: (37:07.725)$90,$55,$1B
    37:07.747: Start reading frame
    37:07.747: Aldl frame header byte: $A0
    37:07.747: Aldl frame length byte: $55
    37:07.747: Recv: $A0,$55,$0B
    37:07.747: Finished reading frame
    37:07.747: (37:07.747)$A0,$55,$0B
    37:07.771: Start reading frame
    37:07.771: Aldl frame header byte: $11
    37:07.771: Aldl frame length byte: $5C
    37:07.771: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:07.771: Finished reading frame
    37:07.771: (37:07.771)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:07.793: Start reading frame
    37:07.793: Aldl frame header byte: $40
    37:07.793: Aldl frame length byte: $58
    37:07.793: Recv: $40,$58,$51,$12,$43,$C2
    37:07.793: Finished reading frame
    37:07.793: (37:07.793)$40,$58,$51,$12,$43,$C2
    37:07.815: Start reading frame
    37:07.815: Aldl frame header byte: $41
    37:07.815: Aldl frame length byte: $63
    37:07.815: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$6B,$DB
    37:07.815: Finished reading frame
    37:07.815: (37:07.815)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$6B,$DB
    37:07.838: Start reading frame
    37:07.838: Aldl frame header byte: $ 8
    37:07.838: Aldl frame length byte: $55
    37:07.838: Recv: $08,$55,$A3
    37:07.838: Finished reading frame
    37:07.838: (37:07.838)$08,$55,$A3
    37:07.860: Start reading frame
    37:07.925: Aldl frame header byte: $40
    37:07.925: Aldl frame length byte: $58
    37:07.925: Recv: $40,$58,$51,$12,$43,$C2
    37:07.925: Finished reading frame
    37:07.925: (37:07.925)$40,$58,$51,$12,$43,$C2
    37:07.948: Start reading frame
    37:07.948: Aldl frame header byte: $41
    37:07.948: Aldl frame length byte: $63
    37:07.948: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$88,$BE
    37:07.948: Finished reading frame
    37:07.948: (37:07.948)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$88,$BE
    37:07.971: Start reading frame
    37:07.971: Aldl frame header byte: $A8
    37:07.971: Aldl frame length byte: $55
    37:07.971: Recv: $A8,$55,$03
    37:07.971: Finished reading frame
    37:07.971: (37:07.971)$A8,$55,$03
    37:07.994: Start reading frame
    37:07.994: Aldl frame header byte: $20
    37:07.994: Aldl frame length byte: $55
    37:07.994: Recv: $20,$55,$8B
    37:07.994: Finished reading frame
    37:07.994: (37:07.994)$20,$55,$8B
    37:08.017: Start reading frame
    37:08.017: Aldl frame header byte: $D8
    37:08.017: Aldl frame length byte: $55
    37:08.017: Recv: $D8,$55,$D3
    37:08.017: Finished reading frame
    37:08.017: (37:08.017)$D8,$55,$D3
    37:08.039: Start reading frame
    37:08.039: Aldl frame header byte: $90
    37:08.039: Aldl frame length byte: $55
    37:08.039: Recv: $90,$55,$1B
    37:08.039: Finished reading frame
    37:08.039: (37:08.039)$90,$55,$1B
    37:08.064: Start reading frame
    37:08.064: Aldl frame header byte: $A0
    37:08.064: Aldl frame length byte: $55
    37:08.064: Recv: $A0,$55,$0B
    37:08.064: Finished reading frame
    37:08.064: (37:08.064)$A0,$55,$0B
    37:08.086: Start reading frame
    37:08.086: Aldl frame header byte: $11
    37:08.086: Aldl frame length byte: $5C
    37:08.086: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:08.086: Finished reading frame
    37:08.086: (37:08.086)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    37:08.108: Start reading frame
    37:08.108: Aldl frame header byte: $40
    37:08.108: Aldl frame length byte: $58
    37:08.108: Recv: $40,$58,$51,$12,$43,$C2
    37:08.108: Finished reading frame
    37:08.108: (37:08.108)$40,$58,$51,$12,$43,$C2
    37:08.130: Start reading frame
    37:08.130: Aldl frame header byte: $41
    37:08.130: Aldl frame length byte: $63
    37:08.130: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$9D,$A9
    37:08.130: Finished reading frame
    37:08.130: (37:08.130)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$9D,$A9
    37:08.153: Start reading frame
    37:08.153: Aldl frame header byte: $ 8
    37:08.153: Aldl frame length byte: $55
    37:08.153: Recv: $08,$55,$A3
    37:08.153: Finished reading frame
    37:08.153: (37:08.153)$08,$55,$A3
    37:08.176: Start reading frame
    37:08.240: Aldl frame header byte: $40
    37:08.240: Aldl frame length byte: $58
    37:08.240: Recv: $40,$58,$51,$12,$43,$C2
    37:08.240: Finished reading frame
    37:08.240: (37:08.240)$40,$58,$51,$12,$43,$C2
    37:08.263: Start reading frame
    37:08.263: Aldl frame header byte: $41
    37:08.263: Aldl frame length byte: $63
    37:08.263: Recv: $41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$1A,$2C
    37:08.263: Finished reading frame
    37:08.263: (37:08.263)$41,$63,$00,$00,$00,$3D,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$1A,$2C
    37:08.286: Start reading frame
    37:08.286: Aldl frame header byte: $A8
    37:08.286: Aldl frame length byte: $55
    37:08.286: Recv: $A8,$55,$03
    37:08.286: Finished reading frame
    37:08.286: (37:08.286)$A8,$55,$03
    Apr 2013
    Ignition on for a minute or so:
    Code:
    40:14.912: Scan for chatter...
    40:14.912: Waiting for Aldl bus silence of at least 12ms...
    40:14.927: Start reading frame
    40:15.058: Aldl frame header byte: $40
    40:15.058: Aldl frame length byte: $58
    40:15.058: Recv: $40,$58,$51,$12,$43,$C2
    40:15.058: Finished reading frame
    40:15.058: (40:15.058)$40,$58,$51,$12,$43,$C2
    40:15.109: Start reading frame
    40:15.109: Aldl frame header byte: $41
    40:15.109: Aldl frame length byte: $63
    40:15.109: Recv: $41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$0C,$39
    40:15.109: Finished reading frame
    40:15.109: (40:15.109)$41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$0C,$39
    40:15.146: Start reading frame
    40:15.146: Aldl frame header byte: $A8
    40:15.146: Aldl frame length byte: $55
    40:15.146: Recv: $A8,$55,$03
    40:15.146: Finished reading frame
    40:15.146: (40:15.146)$A8,$55,$03
    40:15.181: Start reading frame
    40:15.181: Aldl frame header byte: $20
    40:15.181: Aldl frame length byte: $55
    40:15.181: Recv: $20,$55,$8B
    40:15.181: Finished reading frame
    40:15.181: (40:15.181)$20,$55,$8B
    40:15.215: Start reading frame
    40:15.215: Aldl frame header byte: $D8
    40:15.215: Aldl frame length byte: $55
    40:15.215: Recv: $D8,$55,$D3
    40:15.215: Finished reading frame
    40:15.215: (40:15.215)$D8,$55,$D3
    40:15.241: Start reading frame
    40:15.241: Aldl frame header byte: $90
    40:15.241: Aldl frame length byte: $55
    40:15.241: Recv: $90,$55,$1B
    40:15.241: Finished reading frame
    40:15.241: (40:15.241)$90,$55,$1B
    40:15.263: Start reading frame
    40:15.263: Aldl frame header byte: $A0
    40:15.263: Aldl frame length byte: $55
    40:15.263: Recv: $A0,$55,$0B
    40:15.263: Finished reading frame
    40:15.263: (40:15.263)$A0,$55,$0B
    40:15.286: Start reading frame
    40:15.286: Aldl frame header byte: $11
    40:15.286: Aldl frame length byte: $5C
    40:15.286: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    40:15.286: Finished reading frame
    40:15.286: (40:15.286)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    40:15.308: Start reading frame
    40:15.308: Aldl frame header byte: $40
    40:15.308: Aldl frame length byte: $58
    40:15.308: Recv: $40,$58,$51,$12,$43,$C2
    40:15.308: Finished reading frame
    40:15.308: (40:15.308)$40,$58,$51,$12,$43,$C2
    40:15.330: Start reading frame
    40:15.330: Aldl frame header byte: $41
    40:15.330: Aldl frame length byte: $63
    40:15.330: Recv: $41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$21,$24
    40:15.330: Finished reading frame
    40:15.330: (40:15.330)$41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$21,$24
    40:15.352: Start reading frame
    40:15.352: Aldl frame header byte: $ 8
    40:15.352: Aldl frame length byte: $55
    40:15.352: Recv: $08,$55,$A3
    40:15.352: Finished reading frame
    40:15.352: (40:15.352)$08,$55,$A3
    40:15.375: Start reading frame
    40:15.375: Aldl frame header byte: $40
    40:15.375: Aldl frame length byte: $58
    40:15.375: Recv: $40,$58,$51,$12,$43,$C2
    40:15.375: Finished reading frame
    40:15.375: (40:15.375)$40,$58,$51,$12,$43,$C2
    40:15.397: Start reading frame
    40:15.397: Aldl frame header byte: $41
    40:15.397: Aldl frame length byte: $63
    40:15.397: Recv: $41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$3E,$07
    40:15.397: Finished reading frame
    40:15.397: (40:15.397)$41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$3E,$07
    40:15.420: Start reading frame
    40:15.420: Aldl frame header byte: $A8
    40:15.420: Aldl frame length byte: $55
    40:15.420: Recv: $A8,$55,$03
    40:15.420: Finished reading frame
    40:15.420: (40:15.420)$A8,$55,$03
    40:15.442: Start reading frame
    40:15.442: Aldl frame header byte: $20
    40:15.442: Aldl frame length byte: $55
    40:15.442: Recv: $20,$55,$8B
    40:15.442: Finished reading frame
    40:15.442: (40:15.442)$20,$55,$8B
    40:15.465: Start reading frame
    40:15.465: Aldl frame header byte: $D8
    40:15.465: Aldl frame length byte: $55
    40:15.465: Recv: $D8,$55,$D3
    40:15.465: Finished reading frame
    40:15.465: (40:15.465)$D8,$55,$D3
    40:15.488: Start reading frame
    40:15.488: Aldl frame header byte: $90
    40:15.488: Aldl frame length byte: $55
    40:15.488: Recv: $90,$55,$1B
    40:15.488: Finished reading frame
    40:15.488: (40:15.488)$90,$55,$1B
    40:15.511: Start reading frame
    40:15.511: Aldl frame header byte: $A0
    40:15.511: Aldl frame length byte: $55
    40:15.511: Recv: $A0,$55,$0B
    40:15.511: Finished reading frame
    40:15.511: (40:15.511)$A0,$55,$0B
    40:15.533: Start reading frame
    40:15.533: Aldl frame header byte: $11
    40:15.533: Aldl frame length byte: $5C
    40:15.533: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    40:15.533: Finished reading frame
    40:15.533: (40:15.533)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    40:15.555: Start reading frame
    40:15.555: Aldl frame header byte: $40
    40:15.555: Aldl frame length byte: $58
    40:15.555: Recv: $40,$58,$51,$12,$43,$C2
    40:15.555: Finished reading frame
    40:15.555: (40:15.555)$40,$58,$51,$12,$43,$C2
    40:15.578: Start reading frame
    40:15.578: Aldl frame header byte: $41
    40:15.578: Aldl frame length byte: $63
    40:15.578: Recv: $41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$54,$F1
    40:15.578: Finished reading frame
    40:15.578: (40:15.578)$41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$54,$F1
    40:15.600: Start reading frame
    40:15.600: Aldl frame header byte: $ 8
    40:15.600: Aldl frame length byte: $55
    40:15.600: Recv: $08,$55,$A3
    40:15.600: Finished reading frame
    40:15.600: (40:15.600)$08,$55,$A3
    40:15.623: Start reading frame
    40:15.688: Aldl frame header byte: $40
    40:15.688: Aldl frame length byte: $58
    40:15.688: Recv: $40,$58,$51,$12,$43,$C2
    40:15.688: Finished reading frame
    40:15.688: (40:15.688)$40,$58,$51,$12,$43,$C2
    40:15.711: Start reading frame
    40:15.711: Aldl frame header byte: $41
    40:15.711: Aldl frame length byte: $63
    40:15.711: Recv: $41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$70,$D5
    40:15.711: Finished reading frame
    40:15.711: (40:15.711)$41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$70,$D5
    40:15.733: Start reading frame
    40:15.733: Aldl frame header byte: $A8
    40:15.733: Aldl frame length byte: $55
    40:15.733: Recv: $A8,$55,$03
    40:15.733: Finished reading frame
    40:15.734: (40:15.733)$A8,$55,$03
    40:15.756: Start reading frame
    40:15.756: Aldl frame header byte: $20
    40:15.756: Aldl frame length byte: $55
    40:15.756: Recv: $20,$55,$8B
    40:15.756: Finished reading frame
    40:15.756: (40:15.756)$20,$55,$8B
    40:15.778: Start reading frame
    40:15.779: Aldl frame header byte: $D8
    40:15.779: Aldl frame length byte: $55
    40:15.779: Recv: $D8,$55,$D3
    40:15.779: Finished reading frame
    40:15.779: (40:15.779)$D8,$55,$D3
    40:15.801: Start reading frame
    40:15.801: Aldl frame header byte: $90
    40:15.801: Aldl frame length byte: $55
    40:15.801: Recv: $90,$55,$1B
    40:15.801: Finished reading frame
    40:15.801: (40:15.801)$90,$55,$1B
    40:15.826: Start reading frame
    40:15.826: Aldl frame header byte: $A0
    40:15.826: Aldl frame length byte: $55
    40:15.826: Recv: $A0,$55,$0B
    40:15.826: Finished reading frame
    40:15.826: (40:15.826)$A0,$55,$0B
    40:15.858: Start reading frame
    40:15.858: Aldl frame header byte: $11
    40:15.858: Aldl frame length byte: $5C
    40:15.858: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    40:15.858: Finished reading frame
    40:15.858: (40:15.858)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    40:15.889: Start reading frame
    40:15.889: Aldl frame header byte: $40
    40:15.889: Aldl frame length byte: $58
    40:15.889: Recv: $40,$58,$51,$12,$43,$C2
    40:15.889: Finished reading frame
    40:15.889: (40:15.889)$40,$58,$51,$12,$43,$C2
    40:15.921: Start reading frame
    40:15.921: Aldl frame header byte: $41
    40:15.921: Aldl frame length byte: $63
    40:15.921: Recv: $41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$86,$BF
    40:15.921: Finished reading frame
    40:15.921: (40:15.921)$41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$86,$BF
    40:15.943: Start reading frame
    40:15.943: Aldl frame header byte: $ 8
    40:15.943: Aldl frame length byte: $55
    40:15.943: Recv: $08,$55,$A3
    40:15.943: Finished reading frame
    40:15.943: (40:15.943)$08,$55,$A3
    40:15.966: Start reading frame
    40:16.003: Aldl frame header byte: $40
    40:16.003: Aldl frame length byte: $58
    40:16.003: Recv: $40,$58,$51,$12,$43,$C2
    40:16.003: Finished reading frame
    40:16.003: (40:16.003)$40,$58,$51,$12,$43,$C2
    40:16.034: Start reading frame
    40:16.034: Aldl frame header byte: $41
    40:16.034: Aldl frame length byte: $63
    40:16.034: Recv: $41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$03,$42
    40:16.034: Finished reading frame
    40:16.034: (40:16.034)$41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$03,$42
    40:16.057: Start reading frame
    40:16.057: Aldl frame header byte: $A8
    40:16.057: Aldl frame length byte: $55
    40:16.057: Recv: $A8,$55,$03
    40:16.057: Finished reading frame
    40:16.057: (40:16.057)$A8,$55,$03
    40:16.084: Start reading frame
    40:16.084: Aldl frame header byte: $20
    40:16.084: Aldl frame length byte: $55
    40:16.084: Recv: $20,$55,$8B
    40:16.084: Finished reading frame
    40:16.084: (40:16.084)$20,$55,$8B
    40:16.111: Start reading frame
    40:16.111: Aldl frame header byte: $D8
    40:16.111: Aldl frame length byte: $55
    40:16.111: Recv: $D8,$55,$D3
    40:16.111: Finished reading frame
    40:16.111: (40:16.111)$D8,$55,$D3
    40:16.138: Start reading frame
    40:16.138: Aldl frame header byte: $90
    40:16.138: Aldl frame length byte: $55
    40:16.138: Recv: $90,$55,$1B
    40:16.138: Finished reading frame
    40:16.138: (40:16.138)$90,$55,$1B
    40:16.164: Start reading frame
    40:16.164: Aldl frame header byte: $A0
    40:16.164: Aldl frame length byte: $55
    40:16.164: Recv: $A0,$55,$0B
    40:16.164: Finished reading frame
    40:16.164: (40:16.164)$A0,$55,$0B
    40:16.190: Start reading frame
    40:16.190: Aldl frame header byte: $11
    40:16.190: Aldl frame length byte: $5C
    40:16.190: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    40:16.190: Finished reading frame
    40:16.190: (40:16.190)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    40:16.215: Start reading frame
    40:16.216: Aldl frame header byte: $40
    40:16.216: Aldl frame length byte: $58
    40:16.216: Recv: $40,$58,$51,$12,$43,$C2
    40:16.216: Finished reading frame
    40:16.216: (40:16.216)$40,$58,$51,$12,$43,$C2
    40:16.243: Start reading frame
    40:16.243: Aldl frame header byte: $41
    40:16.243: Aldl frame length byte: $63
    40:16.243: Recv: $41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$18,$2D
    40:16.243: Finished reading frame
    40:16.243: (40:16.243)$41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$18,$2D
    40:16.270: Start reading frame
    40:16.270: Aldl frame header byte: $ 8
    40:16.270: Aldl frame length byte: $55
    40:16.270: Recv: $08,$55,$A3
    40:16.270: Finished reading frame
    40:16.270: (40:16.270)$08,$55,$A3
    40:16.297: Start reading frame
    40:16.318: Aldl frame header byte: $40
    40:16.318: Aldl frame length byte: $58
    40:16.318: Recv: $40,$58,$51,$12,$43,$C2
    40:16.318: Finished reading frame
    40:16.318: (40:16.318)$40,$58,$51,$12,$43,$C2
    40:16.345: Start reading frame
    40:16.345: Aldl frame header byte: $41
    40:16.345: Aldl frame length byte: $63
    40:16.345: Recv: $41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$35,$10
    40:16.345: Finished reading frame
    40:16.345: (40:16.345)$41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$35,$10
    40:16.372: Start reading frame
    40:16.372: Aldl frame header byte: $A8
    40:16.372: Aldl frame length byte: $55
    40:16.372: Recv: $A8,$55,$03
    40:16.372: Finished reading frame
    40:16.372: (40:16.372)$A8,$55,$03
    40:16.403: Start reading frame
    40:16.403: Aldl frame header byte: $20
    40:16.403: Aldl frame length byte: $55
    40:16.403: Recv: $20,$55,$8B
    40:16.403: Finished reading frame
    40:16.403: (40:16.403)$20,$55,$8B
    40:16.434: Start reading frame
    40:16.434: Aldl frame header byte: $D8
    40:16.434: Aldl frame length byte: $55
    40:16.434: Recv: $D8,$55,$D3
    40:16.434: Finished reading frame
    40:16.434: (40:16.434)$D8,$55,$D3
    40:16.465: Start reading frame
    40:16.465: Aldl frame header byte: $90
    40:16.465: Aldl frame length byte: $55
    40:16.465: Recv: $90,$55,$1B
    40:16.465: Finished reading frame
    40:16.465: (40:16.465)$90,$55,$1B
    40:16.497: Start reading frame
    40:16.497: Aldl frame header byte: $A0
    40:16.497: Aldl frame length byte: $55
    40:16.497: Recv: $A0,$55,$0B
    40:16.497: Finished reading frame
    40:16.497: (40:16.497)$A0,$55,$0B
    40:16.526: Start reading frame
    40:16.526: Aldl frame header byte: $11
    40:16.526: Aldl frame length byte: $5C
    40:16.526: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    40:16.526: Finished reading frame
    40:16.526: (40:16.526)$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    40:16.554: Start reading frame
    40:16.554: Aldl frame header byte: $40
    40:16.554: Aldl frame length byte: $58
    40:16.554: Recv: $40,$58,$51,$12,$43,$C2
    40:16.554: Finished reading frame
    40:16.554: (40:16.554)$40,$58,$51,$12,$43,$C2
    40:16.577: Start reading frame
    40:16.577: Aldl frame header byte: $41
    40:16.577: Aldl frame length byte: $63
    40:16.577: Recv: $41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$4B,$FA
    40:16.577: Finished reading frame
    40:16.577: (40:16.577)$41,$63,$00,$00,$00,$3D,$3D,$00,$00,$00,$D8,$C5,$00,$00,$00,$4B,$FA
    Nov 2007
    Now you've turned the Serial I/O option on what does it say when you try log?
    Quote Originally Posted by kangsta View Post
    Yes, that's the next step,. Can you post the trace data that is generated when you try to log while the Serial I/O option is still selected.
    Apr 2013
    Is this what you are expecting? Hitting the green button while ignition is on, after it has all settled.
    Code:
    28:39.273: Start macro: Engine data and DTCs: DATADTC
    28:39.289: Synchronising ALDL communications...
    28:39.289: Waiting for heartbeat: $08,$55,$A3
    28:39.289: Waiting for Aldl bus silence of at least 12ms...
    28:39.302: Start reading frame
    28:39.307: Aldl frame header byte: $A0
    28:39.307: Aldl frame length byte: $55
    28:39.307: Recv: $A0,$55,$0B
    28:39.307: Finished reading frame
    28:39.307: Frame:  0 = $A0,$55,$0B
    28:39.307: Start reading frame
    28:39.332: Aldl frame header byte: $11
    28:39.332: Aldl frame length byte: $5C
    28:39.332: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    28:39.332: Finished reading frame
    28:39.332: Frame:  1 = $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    28:39.332: Start reading frame
    28:39.346: Aldl frame header byte: $40
    28:39.346: Aldl frame length byte: $58
    28:39.346: Recv: $40,$58,$51,$12,$43,$C2
    28:39.346: Finished reading frame
    28:39.346: Frame:  2 = $40,$58,$51,$12,$43,$C2
    28:39.346: Start reading frame
    28:39.369: Aldl frame header byte: $41
    28:39.369: Aldl frame length byte: $63
    28:39.369: Recv: $41,$63,$00,$00,$00,$3C,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$0C,$3B
    28:39.369: Finished reading frame
    28:39.369: Frame:  3 = $41,$63,$00,$00,$00,$3C,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$0C,$3B
    28:39.369: Start reading frame
    28:39.382: Aldl frame header byte: $ 8
    28:39.382: Aldl frame length byte: $55
    28:39.382: Recv: $08,$55,$A3
    28:39.382: Finished reading frame
    28:39.382: Frame:  4 = $08,$55,$A3
    28:39.382: Found heartbeat: $08,$55,$A3 - ALDL synchronised
    28:39.382: Send suspend command: $F1,$56,$08,$B1
    28:39.382: Start writing frame
    28:39.382: Send: $F1,$56,$08,$B1
    28:39.383: Finished writing frame
    28:39.383: Start reading frame
    28:39.390: Aldl frame header byte: $F1
    28:39.390: Aldl frame length byte: $56
    28:39.390: Recv: $F1,$56,$08,$B1
    28:39.390: Finished reading frame
    28:39.390: MAX232 echo: $F1,$56,$08,$B1
    28:39.390: Start reading frame
    28:39.526: Aldl frame header byte: $40
    28:39.526: Aldl frame length byte: $58
    28:39.526: Recv: $40,$58,$51,$12,$43,$C2
    28:39.526: Finished reading frame
    28:39.526: Start writing frame
    28:39.526: Send: $F7,$57,$01,$01,$B0
    28:39.527: Finished writing frame
    28:39.527: Start reading frame
    28:39.532: Aldl frame header byte: $ 1
    28:39.532: Aldl frame length byte: $22
    28:39.532: Recv: $01,$55,$00
    28:39.532: Error: Reply frame checksum failure
    28:39.839: Finished reading frame
    28:39.839: Error: No echo received from MAX232
    28:39.848: Start reading frame
    28:39.848: Aldl frame header byte: $13
    28:39.848: Aldl frame length byte: $ 2
    28:39.848: Recv: $13,$55,$00
    28:39.848: Error: Reply frame checksum failure
    28:39.873: Finished reading frame
    28:39.873: Aborting request due to previous error
    28:39.882: Start writing frame
    28:39.882: Send: $F7,$57,$01,$00,$B1
    28:39.883: Finished writing frame
    28:39.883: Start reading frame
    28:39.889: Aldl frame header byte: $F7
    28:39.889: Aldl frame length byte: $57
    28:39.892: Recv: $F7,$57,$01,$A0,$8B
    28:39.892: Error: Reply frame checksum failure
    28:39.927: Finished reading frame
    28:39.927: Error: No echo received from MAX232
    28:39.936: Start reading frame
    28:39.936: Aldl frame header byte: $D8
    28:39.936: Aldl frame length byte: $55
    28:39.936: Recv: $D8,$55,$D3
    28:39.936: Finished reading frame
    28:39.959: Start writing frame
    28:39.959: Send: $F7,$57,$01,$00,$B1
    28:39.960: Finished writing frame
    28:39.960: Start reading frame
    28:39.964: Aldl frame header byte: $11
    28:39.964: Aldl frame length byte: $5C
    28:39.964: Recv: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54
    28:39.964: Finished reading frame
    28:39.964: Error: Max232 echo: $11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54 did not match command: $F7,$57,$01,$00,$B1
    28:40.004: Start reading frame
    28:40.004: Aldl frame header byte: $DF
    28:40.004: Aldl frame length byte: $55
    28:40.004: Recv: $DF,$55,$00
    28:40.004: Error: Reply frame checksum failure
    28:40.027: Finished reading frame
    28:40.027: Aborting request due to previous error
    28:40.035: Start writing frame
    28:40.035: Send: $F7,$57,$01,$00,$B1
    28:40.036: Finished writing frame
    28:40.036: Start reading frame
    28:40.044: Aldl frame header byte: $F7
    28:40.044: Aldl frame length byte: $57
    28:40.044: Recv: $F7,$57,$01,$00,$B1
    28:40.044: Finished reading frame
    28:40.044: MAX232 echo: $F7,$57,$01,$00,$B1
    28:40.044: Start reading frame
    28:40.083: Aldl frame header byte: $F7
    28:40.083: Aldl frame length byte: $A1
    28:40.142: Recv: $F7,$A1,$01,$00,$00,$00,$00,$77,$51,$96,$50,$00,$00,$00,$00,$1C,$00,$60,$00,$67,$00,$0D,$D0,$7A,$80,$80,$80,$80,$00,$00,$00,$93,$7A,$FF,$80,$80,$46,$00,$00,$80,$80,$00,$00,$00,$00,$6B,$00,$00,$94,$9E,$00,$21,$00,$00,$00,$00,$00,$00,$00,$00,$00,$80,$00,$A6,$00,$FF,$C5,$4F,$00,$00,$00,$00,$00,$00,$00,$87,$87,$88,$A0
    28:40.142: Finished reading frame
    28:40.208: Start writing frame
    28:40.208: Send: $F7,$57,$01,$00,$B1
    28:40.209: Finished writing frame
    28:40.209: Start reading frame
    28:40.217: Aldl frame header byte: $F7
    28:40.217: Aldl frame length byte: $57
    28:40.217: Recv: $F7,$57,$01,$00,$B1
    28:40.217: Finished reading frame
    28:40.217: MAX232 echo: $F7,$57,$01,$00,$B1
    28:40.217: Start reading frame
    28:40.234: Aldl frame header byte: $ 7
    28:40.234: Aldl frame length byte: $ 0
    28:40.234: Recv: $07,$55,$00
    28:40.234: Error: Reply frame checksum failure
    28:40.297: Finished reading frame
    28:40.297: Aborting request due to previous error
    28:40.306: Start writing frame
    28:40.306: Send: $F7,$57,$01,$00,$B1
    28:40.307: Finished writing frame
    28:40.307: Start reading frame
    28:40.312: Aldl frame header byte: $80
    28:40.312: Aldl frame length byte: $ 0
    28:40.312: Recv: $80,$55,$A6
    28:40.312: Error: Reply frame checksum failure
    28:40.347: Finished reading frame
    28:40.347: Error: No echo received from MAX232
    28:40.357: Start reading frame
    28:40.357: Aldl frame header byte: $ 0
    28:40.357: Aldl frame length byte: $FF
    28:40.553: Com timeout: Data frame truncated: $00,$FF,$C5,$4F,$00,$00,$00,$00,$00,$00,$00,$01,$01,$00,$EC,$08,$55,$A3,$40,$58,$51,$12,$43,$C2,$41,$63,$00,$00,$00,$3C,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$20,$27,$A8,$55,$03,$20,$55,$8B,$D8,$55,$D3,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00
    28:40.582: Aborting request due to previous error
    28:40.695: Start writing frame
    28:40.695: Send: $F7,$57,$01,$00,$B1
    28:40.696: Finished writing frame
    28:40.696: Start reading frame
    28:40.704: Aldl frame header byte: $F7
    28:40.704: Aldl frame length byte: $57
    28:40.704: Recv: $F7,$57,$01,$00,$B1
    28:40.704: Finished reading frame
    28:40.704: MAX232 echo: $F7,$57,$01,$00,$B1
    28:40.704: Start reading frame
    28:40.743: Aldl frame header byte: $F7
    28:40.743: Aldl frame length byte: $A1
    28:40.823: Recv: $F7,$A1,$01,$00,$00,$00,$00,$77,$51,$96,$50,$00,$00,$00,$00,$1C,$00,$66,$00,$66,$00,$0D,$D0,$7A,$80,$80,$80,$80,$00,$00,$00,$93,$7A,$FF,$80,$80,$46,$00,$00,$4A,$4A,$00,$00,$00,$00,$6B,$00,$00,$94,$9E,$00,$21,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$13,$71,$0A,$00,$00,$00,$00,$00,$00,$51,$51,$51,$AA,$A8,$55,$03
    28:40.823: Error: Reply frame checksum failure
    28:40.931: Finished reading frame
    28:40.931: Aborting request due to previous error
    28:40.947: Resuming normal ALDL communications...
    28:40.947: Send resume command: $F1,$56,$09,$B0
    28:40.947: Start writing frame
    28:40.947: Send: $F1,$56,$09,$B0
    28:40.948: Finished writing frame
    28:40.948: Start reading frame
    28:40.954: Aldl frame header byte: $F1
    28:40.954: Aldl frame length byte: $56
    28:40.954: Recv: $F1,$56,$09,$80
    28:40.954: Error: Reply frame checksum failure
    28:41.012: Finished reading frame
    28:41.012: Error: No echo received from MAX232
    28:41.021: Start reading frame
    28:41.021: Aldl frame header byte: $55
    28:41.021: Aldl frame length byte: $A3
    28:41.302: Com timeout: Data frame truncated: $55,$A3,$40,$58,$51,$12,$43,$C2,$41,$63,$00,$00,$00,$3C,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$85,$C2,$A8,$55,$03,$20,$55,$8B,$D8,$55,$D3,$90,$55,$1B,$A0,$55,$0B,$11,$5C,$FF,$00,$40,$00,$00,$00,$00,$54,$40,$58,$51,$12,$43,$C2,$41,$63,$00,$00,$00,$3C,$3C,$00,$00,$00,$D8,$C5,$00,$00,$00,$9A,$AD,$08,$55,$A3,$00,$00,$00,$00,$00
    28:41.324: Stop macro: Engine data and DTCs: DATADTC
    Timer settings tried
    0, 0, 100, 0, 10, 50
    0, 0, 200, 0, 0, 12
    The second settings seems to work sometimes. Pretty sure I need T3 over 150uS... but most of the others are guess work.
  1. E39 GMH 3.0 SIDI: 91 vs 98 Octane
    By swingtan in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: October 21st, 2015, 10:33 PM
  2. Replies: 6
    Last Post: March 26th, 2011, 04:58 PM
  3. Replies: 19
    Last Post: January 29th, 2009, 09:11 PM
  4. Sometimes communication hangs
    By Ira in forum FlashScan V2 BB Logging
    Last Post: January 2nd, 2008, 09:29 AM
