Results 1 to 1 of 1
Thread: Questions on 102/102 FAST setup to get to idle
    Feb 2006
    Default Questions on 102/102 FAST setup to get to idle
    LMAO....Disregard.. In the heat of the 102 swap battle I found 2 issues.
    1: Even though there looked like alot of room between the intake and water pump I have found that the intake moves quite a bit when torqued down. Further grinding needed tomorrow.
    2: Some dummy did not plug the MAP sensor in.....
    Hello all. I have been an absent member for a long while now due to putting my TA on the back burner a few years back to handle some long term family issues. During that time some new parts collected in the attic over time and this is the spring to jump back into enjoying my car. It seems I have forgotten alot of what I learned here tuning for heads/cam/LS6 intake and ported stock TB and alot has seemed to change in the EFILive tuning world.
    On to the problem.
    I have recently installed a 232/238 cam and FAST 102/102 intake TB combo that will not hold idle to begin the tuning process. Old cam was 231/237 on lazy lobes and intake/TB were LS6/Ported stock TB. I don't believe cam is different enough to keep it from idling and the problem lies with the huge increase to the 102 setup. Can anyone help with just getting this thing to start and idle long enough to get some logs to fine tune the idle and move on from there? The MAF was ditched long ago and have been SD for years.
    Thanks in advance
    Shawn
  1. Replies: 28
    Last Post: November 23rd, 2015, 05:30 PM
  2. Replies: 1
    Last Post: January 29th, 2013, 04:31 PM
  3. changing ls2 90 to fast ls2 102
    By evilperformance in forum Gen IV V8 Specific
    Last Post: November 25th, 2012, 01:23 PM
  4. need help with 102 tb
    By pkriner in forum E37, E38 & E67 PFI ECM's
    Last Post: April 3rd, 2012, 02:36 AM
  5. Idle issue after 90 to 102 throttle
    By wesam in forum Gen III V8 Specific
    Last Post: May 10th, 2011, 12:30 PM
