Results 1 to 9 of 9
Thread: Too much timing being pulled on N2O COS5
    Default Too much timing being pulled on N2O COS5
    Total timing is 28*, for nitrous activation its pulling 18* for a total timing of 10* for nitrous. But its actually pulling 20.5*, running total timing of 7.5* with the nitrous activated.
    Vehicle is a 2000 Chevy Ext cab truck with a 370, L92 heads, 251/267 .623 115+6, Vic Jr intake, Fast 4150 TB, NOS crossbar plate with a .060 jet. SD tune, no maf, no o2's.
    Here is the Tune and Log.
    370 .060 7.5 DEGREES TIMING IN TRUCK NOW 4 7 12.tun
    7.5 DEGREES NITROUS.efi
    Feb 2008
    One thing I've found is you need to have all the tables matched. So high octane, low octane, spark in gear, spark in park, and optimal timing all have to be equal to have the exact timing you want when using the cos timing functions. So just take a little time and closely match the cell values and you should get the result you want.
    LQ4, Pro-Flo, heads, Stock48 cam'd, twin TO4E 2001 C5 830rwhp/905rwtq
    2001 GMC RCSB pt88/5.3/4l80e/14 bolt 11.34@123.2 best pass so far with a 1,82 60' @ 13lbs boost
    Quote Originally Posted by joeygc5 View Post
    Got everything copied and matched. Will try it out tomorrow. Thanks!
    Feb 2008
    Oh and lower B6619 and B6620 by 1-5 to get them back in range. Whats with the throttle position only showing 87.5-88%?
    cant really getthe tps right.. Im on my 3rd tps sensor.. and still reads like that and ive tried to re clock it in the throttle body.
    Feb 2008
    Ah hell, give phantom a rubber mallet
    I'm thinking something bigger than a rubber mallet.. Lol
    Feb 2008
    Any time to test it out?
    Yea I tried it last night. Had it commanded to run 7.5 degrees and it ran 5 degrees. Ill post the tune and log tonight when I get home.. In kinda wondering if it has something to do with the TPS not reading right..
  1. Timing being pulled with no knock detection
    By GLGJR in forum E37, E38 & E67 PFI ECM's
    Last Post: September 7th, 2010, 11:39 PM
  2. New to COS5 setting up N2O
    By ND2RACE in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 10th, 2008, 04:43 AM
  3. What could cause timing to be pulled with no KR detected?
    By ArKay99 in forum Gen III V8 Specific
    Last Post: September 15th, 2008, 09:09 AM
  4. No KR, but timing pulled on launch
    By efizjb in forum Gen III V8 Specific
    Last Post: February 6th, 2008, 02:25 PM
  5. Timing being pulled, but where?
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: December 17th, 2006, 04:19 PM
