Results 1 to 2 of 2
Thread: Cruise Timing
    Feb 2013
    Default Cruise Timing
    So how much timing at cruise is too much? I've added about 10 deg to my cruise timing cells so it's now in the 35-38 deg range, and there was a negligible increase in the average MPG at cruise (64-66mph). I'm logging MPG with a calc pid. The increase was about 0.4 MPG which could be caused by other variables. I did however drive the same exact route at the same speed, roughly same outside temp, etc.
    I made a map of MPG versus RPM and grams/cyl airflow (same as spark tables) and filtered out non-cruise data. Is there a better way to see the change in fuel consumption?
    2001 Silverado 5.3L ECSB 2WD T56:
    T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
    EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
    If you doing lean cruise, take a look at the Holden tunes.
    Map+filter is a good way.
    Also make a map of MPG x LOAD (i.e. engine load) to see if that reveals anything.
  1. E37 unpredictable spark timing and lean cruise
    By MisterBill in forum E37, E38 & E67 PFI ECM's
    Last Post: September 25th, 2011, 03:40 PM
  2. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: November 17th, 2009, 12:15 AM
  3. LMM Diesel cruise timing
    By camcojb in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 24th, 2007, 02:57 AM
  4. A/F @ Cruise SD
    By dirt_track_racer_81 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2007, 06:21 AM
  5. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 08:42 PM
