I've put together a FAQ document that I'll send those customers that purchase AutoCal through us. It's probably still a couple of days away at this point.
The answer to your question is thatonce the AutoCal has been Flashed with the new tuners tunes, the original tuners files can no longer be flashed. You won't need to worry about end users keeping copies of your tunes if they decide to switch.
That said, the process for relinking requires some education. Once you unlink the AutoCal there are 2 methods to relink.
- The tuner connects the AutoCal device to a FlashScan V2 device and selects the link option, or
- The tuner sends a file that was "saved for AutoCal" to the customer and the end user flashes that file into their vehicle.
Tuners and end users should note that if the end user re-flashes a tune file made by the original tuner after unlinking, but prior to flashing a file made by a subsequent tuner, then the AutoCal will be relinked to the original tuners FlashScan V2 device.
Cheers
Cindy
