Results 1 to 2 of 2
Thread: how to read desired vs. actual??
    Mar 2013
    Default how to read desired vs. actual??
    Can some one explane how to read desired vs actual info when scanning with a v2. I'm wanting to view my turbo vane sensor. I'm able to watch actual %, but where does it show desired? Thanks
    If it is a log-able PID, it is separate from the actual PID. In your case, you would need to select the Vane Position Desired PID (not the exact name).
  1. Desired IAC vs Actual IAC
    By JoshH in forum Gen III V8 Specific
    Last Post: February 18th, 2011, 10:51 AM
  2. B0720-FRP: actual or desired?
    Last Post: November 11th, 2009, 05:55 AM
  3. commanded vs actual
    By minytrker in forum General
    Last Post: January 23rd, 2009, 04:12 AM
  4. command vs actual a/f
    Last Post: June 9th, 2006, 01:50 AM
  5. Read posts in search...read tut..LM1 help.
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: March 15th, 2006, 02:00 PM
