Results 1 to 4 of 4
Thread: Upgrading 1999 Corvette to 2002 OS (12212156)
    Mar 2007
    Default Upgrading 1999 Corvette to 2002 OS (12212156)
    Working on a 99 Corvette. I am wanting to update it to 2002 OS (12212156), but was concerned if there were any issues with this update. One example that I can think of is on trucks, there was a change in the alternator wiring on the newer OS which you have to make to the truck, or just simply turn off the DTC(s). I have always heard that Corvettes are kinda picky, so has anyone else successfully updated a 1999 to 02 OS?
    Were there any issues with this?
    As long as I put in the correct VIN #, shouldn't all the other modules (BCM, etc...) still work and be happy? or would I still need to the a re-learn.?
    Thanks,
    Be sure to use the Corvette specific 12212156 file (because you want the DBW settings).
    For alternator options first look at tables G1206,7 in the 122121567 file.
    Write the correct VIN from the scantool; and then do VATS relearn from the tunetool.
    Later you would also have to do CASE relearn if you're going to use misfires.
    For the Corvette, you might want to disable BCM and On-Star before full flashing to be safe (but not necessarily sure about this).
    Mar 2007
    joecar,
    Thanks for the advice. I had forgotten about having to do the CASE after updating the OS. So even if I keep the same VIN #, I will still have to do a VATS relearn?
    Anyone else successfully update a 99 to an 02?
    with the correct (same) VIN then VATS relearn is simple.
  1. upgrading from 99 to 2002 OS? really worth it?
    By rumblebox in forum Gen III V8 Specific
    Last Post: October 3rd, 2012, 08:15 AM
  2. Looking for a .tun file 2002 Silverado 6.0 LQ4, 4L80E, 4x4 with a 12212156 OS
    By L31Sleeper in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2010, 07:54 PM
  3. Trouble loading 2002 OS in 1999 PCM
    By Beer99C5 in forum Custom Operating Systems
    Last Post: October 9th, 2007, 05:20 AM
  4. 1999-2002 Camaro wanted
    By emarkay in forum Lounge
    Last Post: March 25th, 2007, 02:30 PM
