The description of the relevant tables (B3201, B3202, B3203) mentions that a prime pulse of fuel will be delivered when the ignition key is first turned to the "on" position. Does that mean when the starter is actually engaged or just when the key is turned to the position to where power is applied to the PCM? The reason I ask is because I am trying to firm up the start-up and I tend to turn the key on and allow it to set for a couple of seconds to get the fuel pressure up before actually starting the car. Cold start up is kind of weak, so I'm trying to figure out how to get a more solid sounding start up.
And along the same lines, at what point is the engine actually considered by the PCM to be "started" and the "after-start" tables kick in?
